J
Jim Cockfield
Guest
Yea.. The OP's video card is already much faster than needed, as I pointed out in this post:SushiEater wrote:
Do you realize that any kind of benchmarking is like getting a Ferrari and driving it 65mph?
Some of the benchmark operations are never going to be used in real life or at least not very frequently.
Yet those scores are included. If I was doing something in Photoshop over and over again that requires one specific operation I might consider doing a research on it. But most photographers at best using standard operations that mostly required CPU power and nothing else.
http://www.dpreview.com/forums/post/51955264
As for the CPU, it's not hard to find a variety of different benchmarks of it for use with apps for image editing (anandtech, tom's hardware ,etc.)
But, even though it's not the absolute fastest CPU on some tests like that, as time passes, I'd expect it to move up in the ranks (as some of the existing apps are not written well enough to spin off more threads to take advantage of the 6 physical cores in the Core i7 3930K yet, but future versions will probably take better advantage of more cores).
In any event, the AMD CPU mentioned is just not in the same class as a Core i7 3930K (even if looking at single threaded speed, where AMD tends to lag well behind newer Intel CPU designs as far as performance/thread).
For many users, it may be just fine. But, it looks like the OP wants a "top of the line" type of system with some future proofing for newer apps that will take better advantage of more cores later (and the Core i7 3930K should be a pretty good choice).
If it were my money, I'd probably go with a much cheaper Core i7 3xxx model (probably just buying a refurbished XPX 8500 from Dell for around $700 with a Core i7 3770, 2GB Drive, 8GB of memory, reasonably fast video card like their OEM version of the GT 640 with 1GB of GDDR5. Then, add a fast SSD and more memory to it.
That way, I'd have a system that gives me around 90% of the performance for the apps I use more often for well under half the cost of the system the OP is building. ;-)
The last 10% or so increase in speed tends to cost you a lot more (just as you may spend a lot more for an automobile that's a little better in some areas).
But, then again, time is money to many users (so spending 2 or 3 times as much for a PC to get a little better performance may be well worth it to them in time savings over the life of the PC).
As for me, I'd probably just buy an off-the shelf reburb, add some memory and an SSD, and end up spending less than half of that for a system that's close to 90% as fast. ;-)
I built my own computers for years (so many of them I've lost count). But, lately (for about the last 6 or 7 years), I haven't bothered, since I can find good deals on refurbs from Dell Outlet (for a lot less than I could build equivalent machines for), and just add memory, video card, hard drives, etc. as needed to them (saving a lot of money over buying the parts and putting one together from scratch myself).
On the downside, BIOS setups Dell uses don't allow Overclocking. But, to me that's not a big deal (as you're saving so much money, you can upgrade to a newer generation CPU more often when buying the refurbs from Dell Outlet -- especially if you watch for coupon codes to get even more off the already discounted refurb pricing).
I've bought 3 desktops and 2 laptops that way so far (refurbished from Dell Outlet, waiting for coupon codes for even more off), just upgrading memory, drives and video cards myself (and even swapping out the PSU in one system for a higher wattage model supporting a higher end video card). If you're a good shopper, you can find some pretty good deals that way (ending up with a system for less than you could buy the parts for). ;-)
JimC
