gipper51
I disagree. Seems we work in different manners on image processing. Besides the operations in that test, I can tell you the following:They are trying to sell you a graphics card as well Gipper... Look at their own data. The improvement over built-in GPU is significant only in very infrequent operations, and insignificant in the common operations when you are spending 10X that time looking at the image and pondering your next adjustment.Put into context, they say don't spend the money on a more powerful card than their recommendation of a 1060 or 1070. They don't say skip the GPU altogether as you imply. Geez you have a weird way of distorting facts to suit your stance.Thanks! "For most users, you will be better off in the long run spending that extra money on more RAM, storage, or a higher-end CPU".Just in case you're still adamant that a graphics card has no use in Lightroom or Photoshop, you might find this reading useful. I'm sure it won't change your mind...I mean, why let facts get in the way of a good opinion, right?
https://www.pugetsystems.com/labs/articles/Photoshop-CC-2018-NVIDIA-GeForce-GPU-Performance-1139/
My only disagreement is about the "higher-end CPU"; but then again, Puget sells them.
Spend that extra money on something else entirely.
The full quote that you cherry picked a portion of:
"Overall for Photoshop, we recommend using either a GTX 1060/1070 video card even if you have the budget for a more powerful card. For most users, you will be better off in the long run spending that extra money on more RAM, storage, or a higher-end CPU rather than a more powerful video card."
- I use a 4K monitor plus a pair of 2K monitors (3 total). If I turn off the GPU acceleration in ACR, zooming into images becomes slower and panning around is choppier. With GPU on, zooming is instant and panning is smooth as silk.
- 4K monitors slow Photoshop's response time compared to lower res monitors. 4x the amount of pixels to push. The higher the resolution goes, the more the GPU matters with common operations.
Just the nature of the beast if you prefer that kind of resolution. Is it enough of a slowdown to really impact workflow? Not always but often times can. If I'm crunching through lots of images, say like from my kid's soccer or basketball games it's noticeable. Many things are batch adjusted, but zooming to check sharpness and cropping most of them, those fractions of a second delay become irritating when you're working fast.
Often times I'm not sitting there 'pondering my next adjustment' for 30 seconds, but wanting to crank out a couple hundred images quickly with a methodical workflow. When doing this, the speed makes the work more enjoyable and saves time. I'm sure to you that sounds trivial.
My site:
http://www.gipperich-photography.com
