While I am using the Sony a7III, this probably applies to most models.
Since getting the unit I had made it a best practice to reformat the SD card whenever I wanted to clear up storage space. So whenever it was getting somewhat full, I would connect it to my PC, copy my images to the local HDD, then format the card inside the camera. As this would also delete the M1-M4 settings, I would keep a local copy of my 'PRIVATE' folder around which I manually put onto the drive again after formatting.
This is of course a lot of overhead, especially since one needs to manually copy back the PRIVATE folder to not lose certain settings. The reason I am doing this is because it was officially recommended by Sony. But over time and getting more confident with the camera, I am increasingly wondering whether this is just exaggerated and one can easily just delete files off the SD card in the PC, then put the card back in and not worry about reformatting on a frequent basis.
I have done this a few times too and not noticed any problems. What is still holding me back from skipping this step for good is that I do not know if Sony might create some internal library/index file so when you remove/modify stuff off-camera on your PC, it might lead to issues. I definitely do not want to risk ever losing data just because of this.
But if several other users here have long term experience not doing this and can confirm this is not a problem, I would feel encouraged enough to also drop this task for good.
