OpticsEngineer
Thanks. To simulate the fabrics I might just stick with line-pairs as they also generate color fringes. But the concentric circles are a really good addition since the moire patterns really leap out.
If you can, stick to a sinusoidal target instead of line pairs, it makes Michelson Contrast immediately useful. Lines introduce harmonics, which complicate the readings and related calculations.Thanks. To simulate the fabrics I might just stick with line-pairs as they also generate color fringes. But the concentric circles are a really good addition since the moire patterns really leap out.
Fair enough. But is it then the pixel size or the changing reference sharpness that affects the DoF? To me it seems like it is more about the latter."How are you defining acceptable sharp focus?"
For the purposes of how I am approaching this, whatever sharpness there is at best focus I would define as acceptably sharp. So that is our reference level of contrast.
Then we move away from best focus and we reach points before and behind where the contrast has been reduced to 50% of the reference contrast.
For me, "special occasions" happen more than once or twice.JackHowever, once one starts playing with this stuff one soon realize that we often err on the wrong side of aperture size, tending to prefer larger f-numbers for safety, therefore dropping sharpness at the scene. Never, ever f/16 for critical shots with today's equipment (ok, maybe just once or twice for special occasions).
DOF is a region of acceptable perceived sharpness. If none of the image falls into that category, there is no DOF.Fair enough. But is it then the pixel size or the changing reference sharpness that affects the DoF? To me it seems like it is more about the latter."How are you defining acceptable sharp focus?"
Point well taken John. My comments to Aaron are to be taken in the context of his article, large prints of landscapes.For me, "special occasions" happen more than once or twice.However, once one starts playing with this stuff one soon realize that we often err on the wrong side of aperture size, tending to prefer larger f-numbers for safety, therefore dropping sharpness at the scene. Never, ever f/16 for critical shots with today's equipment (ok, maybe just once or twice for special occasions).
The Cannon upper and lower focus distances are not the far and near depths of field. Although these EXIF tags are proprietary to Canon, I believe, they give you a range for the focus distance, eg https://photography.grayheron.net/2021/08/m3-landscape-bracketing-script-where.html...
Maybe this was a "special occasion" because subject movement prevented focus stacking and subject would leave if photographer got too close. It seems to me that in some circumstances F/16 might be the compromise that captures the most data.
Gulf fritillary (Agraulis vanillae) on Zinnia in Norman, Oklahoma, United States on September 15, 2024 ; Canon EOS R5 ; EF100-400mm f/4.5-5.6L IS II USM +2x III ; F Number 16.0 ; 800.0 mm
Using the circle of confusion reported by the camera in the metadata, Focus Distance Upper2.4 m, Focus Distance Lower2.2 m. But for me the depth of field seems much shallower because I view the image on a screen at 100%.
This was processed using the Canon "digital lens optimizer", but I expect that Richardson/Lucy capture sharpening in rawtherapee would produce similar results.
All of the edits done in Canon DPP software:
Shot with:
- RawBrightnessAdj : 0.67
- WhiteBalanceAdj : Daylight
- WBAdjColorTemp : 5200
- ColorSaturationAdj : 1
- UnsharpMaskStrength : 2
- UnsharpMaskFineness : 1.7
- UnsharpMaskThreshold : 3
- LuminanceNoiseReduction : 1
- ChrominanceNoiseReduction : 1
- ColorMoireReductionOn : No
- ColorBlurOn : Yes
- DLOSetting : 75
- GammaWhitePoint : +1.300
- CropX : 1592
- CropY : 1064
- CropWidth : 6600
- CropHeight : 4400
CircleOfConfusion : 0.030 mm calculated by exiftool
- ExposureCompensation : -2/3
- Quality : CRAW
- CameraISO : Auto
- MeteringMode : Evaluative
- MeasuredRGGB : 1156 1024 1024 277
- WB_RGGBLevelsAsShot : 1967 1024 1024 2123
- ColorTempAsShot : 4803
- WhiteBalance : Auto
- MeasuredEV : 14.00
- MeasuredEV2 : 29
DOF : 0.005 m (2.297 - 2.303 m) calculated by exiftool
Exposure compensation was to avoid clipping reds in raw. Post processing increase in "GammaWhitePoint" was to use all of the red data and avoid clipping reds in JPEG.
( Downscaled image is at https://www.rsok.com/~jrm/2024Sep30_birds_and_cats/2024sep15_butterfly_IMG_1542c.html , GraphicsMagick did an additional unsharp mask after scaling with the default algorithm )
In that context I agreePoint well taken John. My comments to Aaron are to be taken in the context of his article, large prints of landscapes.For me, "special occasions" happen more than once or twice.However, once one starts playing with this stuff one soon realize that we often err on the wrong side of aperture size, tending to prefer larger f-numbers for safety, therefore dropping sharpness at the scene. Never, ever f/16 for critical shots with today's equipment (ok, maybe just once or twice for special occasions).
Jack
So far as I can see, none of Aaron Priest's websites are available. The only sites showing his material are managed by other people, and show examples of his panoramic and 360 degree photos, with supporting commentaryWith a different approach, Aaron Priest says his photographer friends ask him why his landscapes are sharper than theirs, such as a 36x24 inch print viewed at ten inches. Hyperfocal Distance, Depth of Field, Circle of Confusion, Diffraction, and Print Size - Aaron Priest Photography (edit: apologies that this link doesn't seem to work anymore) He enters a two-pixel CoC of about 0.009 mm into a DOF calculator while his friends enter “full-frame.” So, Aaron takes photos with a hyperfocal distance three times longer and he captures more detail.
Ll
