I know the 300d doesn't let you select servo mode, except in sport mode. But that is a different issue than predictive focusing vs. not.well, perhaps you should try a 300d and then you will understand
taht it does not work as a 10d.
You certainly may not get focused flight shots because the camera doesn't kick in servo mode consistently, but when it does, you will want to use the predictive focusing in the situation were talking about. Your still better off and will get more keepers than any other way IMO.
If predictive focusing is not being used, maybe part of this observed AI focus inconsistency is attributable to that.
Gene
--You just cannot force the camera to use AI servo easily. sometimes
it does sometimes it don't.
You can use the servo in sport mode but then you loose everything
else..ISO, shutter, F, WB..you name it..not even raw support.
read the dpreview review for the 300d and you will have a better idea.
--Thats what I am confused about. What Paul is doing as he describes
it, by fully depressing the shutter and not continuously tracking
and taking a sequence of shots, sounds like attempting to get
oneshot out of AI focus mode on a moving subject, which I am not
sure what the outcome would be, but if succeeded, would be affected
by shutter lag. But it sounds like he had a long day, so maybe his
description isn't accurate. Anyhow, tomorrow.
Gene
--10D and 300d don't work the same way.
--You said single shot Paul. I took that as oneshot, which on the 10d
that is AI servo/AI off, no predictive focusing at all. I think you
meant single frame as opposed to continuous frame. Since you are
using AI fousing that should take care of any shutter lag, unless
the AI it hasn't kicked into servo mode. That may be a possibility.
I use the servo mode on the 10D and get good results coming, going
or sideways.
Gene
--oh really?else you will see shutter lag between when you half depress the
shutter button and AF locks, and when you fully depress it and the
shutter (after lag) fires.
Servo mode has predictive focusing that will continue to focus baed
on the motion during this lag period.
I have to try this.
Gene (the hawkman) - Walk softly and carry a big lens
Please visit my galleries at: http://www.pbase.com/gaocus/
Minë Corma hostië të ilyë ar mordossë nutië të
Mornórëo Nóressë yassë i Fuini caitar.
Un thoron arart’a s’un hith mal’kemen ioke.
Saurulmaiel
Saurulmaiel
