Tony Beach
- Messages
- 11,967
- Solutions
- 5
- Reaction score
- 7,035
The issue is that a longer lens (not so much for the short focal lengths hypothesized below) is going to move more than a shorter lens; it's not about the sensor moving differently, it could even not move hardly at all and essentially the same on both formats and this would still be an issue of longer focal lengths magnifying shake more and being more prone to vibration.There is an easy way to visualize the compromises involved in equivalence: insert the mFT sensor half-way between the lens and a FF sensor. Now move both sensors up and down the same absolute amount. Which image is affected more?All else isn't equivalent though. Focal length for any given FOV is greater for the larger format so that will magnify any shake more.Jack Hogan wrote: Vertical/Horizontal hand shake, for instance, affects the smaller format proportionally more, all else equivalent.
Yes, but a shorter lens that is heavy is still going to be less shaky than a longer lens that is equally heavy.From this article :
Of course there is going to be a size/weight sweet-spot for the given application, the D500+500mm/5.6 PF being right in there for birding for instance.On top of that the longer focal length is a bigger lens, unless we are compensating for maximum apertures, so on telephoto lenses that's likely to add to shaky handling.
But to put a finer point on it, my birding friends remind me that "there's no substitute for square mm of pupil area". Once you start with that premise, equivalent lenses end up pretty well having similar bulk/weight/cost on all real photography formats.
As much as I agree with you here, that's a different issue.If they don't it's because the relative manufacturer has taken shortcuts, hoping that its intended audience will not notice that they are no longer comparing apples to apples vs the competition![]()
