Steen Bay
As I understand it, then lenses designed for a smaller image circle can theoretically be sharper, measured as lp/mm on a sensor with infinite MP count. A mFT lens on a 20mp mFT camera (with smaller pixels) has to be sharper in order to resolve the same lp/ph as a FF lens tested on a 20mp FF camera (with larger pixels). Or to be more accurate, then it should rather be same vertical pixel count, because of the different aspect ratios.Let's say we have two sensors, one twice the size (4x the area) as another, and, for the sake of simplicity, assume no AA filter. Let's say we use two lenses that each have the same resolution (lp/mm) at the same DOF (e.g. f/4 and f/8).
How will the resolution in the photos (lw/ph) compare if:
Repeat the question where the lens used on smaller sensor is twice as sharp (lp/mm) as the lens used on the larger sensor.
- the sensors have the same pixel count?
- the sensors have the same pixel size?
Do the answers depend on the contrast level at which the sharpness level is measured?
So, are mFT lenses sharper than FF lenses in practice? Have been discussed in many long threads, but not so many hard facts, because the lenses are tested on cameras with different pixel size. Though, should be relatively simple to find out. If testing some good mFT lenses and some good FF lenses + adapter on the same mFT camera, then that should give us a good idea about how sharp the lenses actually are.
