At other sensor sizes that should be rather easily doable.
In 10ms light travels 3.000km so the length of the signal path is not a limiting factor here. There should be absolutely no problem to do 10ms readout in full frame.
What I was mainly trying to point out is that given that one sensor manufacturer makes the sensors for m43, aps-c and ff and has more of a "personal" interest in aps-c and ff it is unlikely that m43 will get a competitive advantage from that manufacturer for very long.
Lazy buggers, fire them !Right, until we can move electrons as fast as light - not likely.
And this is the best m4/3 sensor ever?
It's 1/2 stop worse in low light than a 5d2 sensor....
It has the same color quality....it took 8 years to catch up?
The rationalization people have to do to feel good about their cameras....
Anyone know if it has any sort of flicker detection like on the 80D?No, you can certainly not assume that.Can I assume that the em1-mk2 electronic shutter is not susceptible to banding with any types of artificial lighting?
It enables you to get pics that you couldn't otherwise, e.g. that would be too blurred or noisy.But if the limit of quality his progressively higher, what sense would have a FF with extraordinary results at 102.400iso?
It would be just as extraordinary in M4/3 at 25.600iso ... is it really needed more? Many years ago it was used as standard large format or at last, 6x6, But Leica appeared with the 35mm (the now FF) ... not comparable in quality, but it was imposed by size, weight and convenience while the quality of the films improved ... despite it has (too) not as narrow DOF at full aperture (… another typical complain against M4/3)
JReg
Canon has brought out a firmware update to the 80D that now eliminates rolling shutter completely, with excellent quality and high fps. It has a small drawback, it crops a central area of one pixel, but it's a good one.Correct. Using same sensor technology the smaller sensor would always have a faster sensor readout.If indeed Sony were to apply the same technology to an apc-s and a full field, sensor, wouldn't sensor readout speed still be faster with the M43 sensor as readout speed would necessarily decrease in proportion to sensor size?
Your figures are false because there is no truth to Equivalence. There is also no truth to gravity. Once the hovercraft, airplanes and other such devices were invented, gravity went out the window and became a false science.M43 ISO 1300 (30db)
means
APS ISO>2000
FF ISO>5000
so, it' just a hyper leap.
