chrisfisheye
- Messages
- 2,005
- Solutions
- 4
- Reaction score
- 1,403
The minimum shutter speed does not really depend on sensor size. Otherwise you could choose the most advantageous format which allows the slowest shutter speed.I may have asked this question a long time ago but forgot what the "answer" was. This really isn't a beginner's question so much but more a question on technique as it relates to some basic concepts of photography and exposure I guess, mainly shutter speed as it applies to different formats.
So, we are generally told that the minimum shutter speed should be at least 1/focal length, but I'm assuming this implies a FF focal length, and does not factor in any stabilization as this rule has been around since before lens/body stabilization...
Using APSC an example, with a 1.5 crop, would we also multiple the shutter speed by 1.5x to determine a safe min shutter speed since the crop results in a narrower field of view, and shake is more visible at narrower/longer focal lengths in general? So if I have a 35mm FF lens on an APSC body, which is roughly at 52mm equivalent, my minimum shutter speed should be around 1/60s correct?
(I know that aperture and ISO and lens/body stabilization are also factors, but I'm looking strictly at the scenario of no stabilization and trying to keep this simple for my own reference.).
The rule of thumb is correct (and must simply adapt with the photographer skills and potentially by the use of stabilisation). It uses the equivalent FL, so this is equivalent to say that for a fiven angle of view, it will require the same minimum speed.
