Ross Dillon
Before camera stabilization became a thing, to avoid seeing camera shake in the images the rule of thumb I was taught was to shoot a shutter speed equal to or faster than the focal length, i.e. a 400mm lens means shooting no slower than 1/400s. I've since read that with today's higher resolution camera that maybe we should double that (400mm = 1/800s).
Does this mean that crop factor kicks in as well; shooting M43 (2x crop factor) now bumps that up to 400mm = 1/1600s?
I ask because I went on a safari with my OM-2 MK II and a non-pro 100-400mm telezoom. I say non-pro because it doesn't have the IS Sync that the pro lenses have. I lost a lot of shots that I thought should have come out...I had inadvertently left my custom setting shutter speed set for a much shorter lens but a few stops of IBIS should have saved them but in many cases didn't.
Note I tried to back off from 400mm as I'd heard that the lens was soft at full zoom, but in the heat of the moment I didn't always remember, so I'm pretty sure that contributed to many of my "lost" shots.
The marketing brochures for the lens was confusing in terms of how much total IS one would get with that lens/camera combo...I even reached out to OM systems to get their answer and they tap danced around the question. I've since heard that per anecdotal use® the lens should have it's IS turned off as it sometimes fights the camera. Really cranky that I hadn't found that tidbit before I left for Africa (if in fact it's true)
