How to replace IR-block filter on *ist D
I wish I had the courage to try something like that. Your entire setup is quite impressive. It comes as no surprise that you are an engineer. I am really looking forward to seeing some of your results.
Tengo una remera del Che, y no sé por qué
Steveo T, I'm working as Process Engineer, but I'm a theoretical Physicist :-)
I haven't used the modified *ist D yet, but I added to the web page a picture of M42 taken with the regular *ist D.
Here is the picture. It is made of multiple 10s, 30s, 120s and 180s images, all taken with noise reduction off. Temperature was about 7C. I took dark fields, bias, flats and flat darks to do the calibration. I still need a lot of work to make this image release its full potential... PP is more difficult than actually taking the shots!
Vincenzo
Hi there.
I have been using an istD for astrophotography for some time and find that the dark frame subtraction in camera is far superior to anything I can construct myself (using Deep Sky Stacker) including flats, offsets and dark frames when in the noise off mode. The price is of course half the exposure time. I feel that the quality of the end product is worth it for myself. Here is an image of the Orion nebula M42 using in camera dark frame subtraction:
http://picasaweb.google.com/dahyon2001/OrionM42060209#5309368060244824578
I find the idea of an istD that is IR enabled very appealing.
Good Luck and clear skies.
David
Hello David,
In camera noise is something I'm planning on testing for sure. I like your image! What optical system did you use?
Vincenzo
Hi there.
David
Hello Vincenzo
I put the equipment information in the notes section of the picasaweb folder but as this is my first attempt - I seem to have messed up. I use a Pentax SDUFII 100mm F4 astrograph at prime focus together with the istD which is of course unmodded, I have tried it on some emission nebulae but it is just not sensitive enough. I am not skilled in electronics to take on the project you have so clearly and expertly illustrated.
clear skies
david
I see, I haven't tried the 400/2.8 at prime focus yet on M42. Also the camera I used for the picture was taken with a unmodified camera. I also did a shot of horse head nebula with the same camera and sure enough there was nothing. I will have to wait a bit for clear skies and free time before I can test the modified *ist D on astro photos...
Just for curiosity, how do you focus?
Ciao,
Vincenzo
Hello Vincenzo
clear skies
david
