Kolari drop-in empty frame and Optolong L-Para dual band filter
Hello everyone, here I share a review of a very interesting solution to use 2" astrophotography filters in our mirrorless cameras, through a drop in filter system. I also talk about the Optolong L-Para dual band filter for astrophotography with wide angle lenses. I hope it helps.
Intro
The emergence of drop-in filter systems has revolutionized the use of astronomical filters on mirrorless cameras. However, until now, commercial options for this type of system were limited to IDAS filters, the only ones available with an integrated drop-in frame. But recently, a new product from Kolari Vision has emerged that has changed the landscape: the Empty Drop-In Filter, which allows any standard 2" astronomical filter to be inserted into it (and therefore also into the drop-in system). Although Kolari states on its website that this frame is designed for both its drop-in system and the Canon one, we have found that it also works perfectly with the Meike MK-EFTE-C drop-in adapter, which greatly expands its usefulness, allowing it to be used not only with Canon cameras but also with Sony and Nikon cameras. Thus, the Kolari Empty Frame is a very interesting option, as it allows you to use not only a huge number of astronomical filters, but also reuse the filters you already have for your dedicated cameras and/or telescopes.
[ATTACH alt="Kolari empty frame + 2" astro filter from Optolong"]3730030[/ATTACH]
Kolari frame inserted in the Meike Drop in adapter Canon EF to Sony E mount
Kolari empty frame
The construction of the Kolari blank frame is very good. It combines metal and high-quality plastic. Insertion into the drop-in system is snap-fit, ensuring it is securely fastened and sealed, preventing light from leaking in. The frame itself has a second threaded internal frame that serves to hold the inserted filter. This thread can be unscrewed and re-screwed once the filter is in place using an included tool that inserts into the two slots in the second frame. This tool is also useful, of course, for unscrewing and removing the glass from any standard 2" astronomical filter that has this attachment system, which most filters do. I have personally tested the Kolari blank frame alongside the Optolong L-Para filter, which I discuss below.
Kolari empty frame
Kolari empty frame
Optolong L-Para
The Optolong L-Para is a new generation dual-band filter designed for color cameras. It captures Ha and OIII simultaneously, with a bandwidth of 10nm in both cases. It is, therefore, a quite restrictive filter, very powerful and effective in highlighting the reddish colors of the night sky and oxygen-rich regions, even with fast, wide-angle lenses. Regarding its transmittance, it is around 85% from f2 onwards and, according to Optolong, it also has very powerful contrast, anti-halo and light pollution emission blocking characteristics. With these characteristics, the L-Para is a direct competitor to the IDAS NBZ-II, which is considered, today, a reference dual-band filter. Regarding the Idas, and still on paper, the Optolong L-Para has slightly wider Oiii and Ha bands (10nm compared to 8nm for the Oiii and 10nm for the H-alpha of the NBZ-II). Personally, I bought it in 2" so that, as explained, I could remove the glass from its frame and place it in the empty Kolari frame, where it fits perfectly, and so that, in the future, if the need arises, I could use it in a filter-holder system for telescopes.
Optolong L-Para 2"
Optolong L-Para 2"
Results and impressions
The results obtained with the L-Para have been very good. The filter has proven to be very effective at capturing H-alpha, blocking light pollution, and producing highly contrasted and saturated bicolor images (blueish/greenish and red). The images obtained are very similar to those obtained with the Idas NBZ-II, except for some nuances, which is why they will (almost) always have to be combined with RGB images. Compared to the Idas NBZ-II, the Optolong L-Para seems to contrast the image a little more, obtaining a little more structure in the Milky Way nebulae. At the same time, it has a bluer cast and seems to separate the reds of the H-Alpha somewhat more from the rest of the colors (blues and greens). It remains to be seen whether this is due to the "blue shift" (the effect of shifting the filters toward blue tones due to shooting at large apertures) or the filter's own cast. As for the H-alpha capture, it's very similar to that of the NBZ-II. If I had to say something, I'd say it might capture a bit less H-alpha than the NBZ-II at large apertures, but the difference, if it really exists, is minimal. The same goes for image quality, which is very similar in both filters, although it may (just may, again) be slightly superior in the case of those obtained with the NBZ-II. As for halos, I haven't noticed any; while I haven't noticed them with the NBZ-II either, the L-Para does seem to perform better in this regard, according to some reviews by other photographers that can be found on YouTube. Finally, and no less importantly, it's worth noting that the L-Para is currently significantly cheaper than the IDAS NBZ-II, making it a very interesting option considering its performance is very similar to that of the IDAS.
Photograph obtained with the L-Para filter (above), at 11mm, 2.8, ISO 4000 and 2 minutes of exposure, and with basic exposure and white balance settings.
Comparison of images obtained with the L-Para filter (top) and the Idas NBZ-II filter (bottom), with uncorrected white balance (left) and corrected white balance (right). A single shot at 11mm, 2.8mm, ISO 4000, and a 2-minute exposure.
Conclusions
Kolari's empty drop-in frame represents an innovative and highly versatile solution, allowing the use of standard 2" astronomical filters on mirrorless cameras. Its compatibility is not limited to the Kolari drop-in system for Canon, or Canon's own, but also extends to the Meike MK-EFTE adapter, making it functional with Sony and Nikon cameras. The frame's build quality is remarkable, combining durable metal and plastic materials. The filter's screw-on attachment system, thanks to the included tool, facilitates filter mounting and removal, allowing for secure, sealed, and light-leak-free use. As for the Optolong L-Para filter, it has proven to be a serious competitor to the IDAS NBZ-II, the current dual-band reference. The L-Para delivers highly contrasted and saturated images and is especially effective in light-polluted conditions and with fast lenses. Although the L-Para's performance is very similar to that of the IDAS NBZ-II—with some differences—it is not surprising that the filter is not suitable for use with other lenses. subtle in contrast, saturation and color separation—, its considerably lower price makes it a very attractive option for astrophotographers looking to maximize results without breaking the bank.
Final result of a panoramic photograph in which the sky is composed of photographs taken with the Optolong L-Para (a single shot per panel at 11mm, f2.8, 2 min, ISO 4000) in combination with RGB photographs (a single shot per panel at 11mm, 2.8, 30 sec, and ISO 800).
Final result of a photograph in which the sky is formed by a photograph taken with the Optolong L-Para (at 11mm, f2.8, 2 min, iso 4000) in combination with an RGB photo (a single shot per panel at 11mm, 2.8, 30s and iso 800).
Great article! I have the Kolari Empty drop in filters to use with my EF lenses and EOS R5 camera. I just have to decide what astro filter to buy. I am new to astrophotography and live in a light-poluted city in northern Europe.
