Roger Krueger
Sure you can. For normal (non-Tmax) negative films adding a half-stop for every metered stop over 1 sec. is almost always close enough.On the contrary. With film, exposure times cannot be allowed to grow too long. The reciprocity of extending exposure duration to compensate for lower light levels at the image plane, breaks down, and the film loses sensitivity. This is called Reciprocity Law Failure.
It isn't just a loss of sensitivity, which is inconvenient enough, because you CANNOT fix it by simply giving longer exposure times, of course....
Slide film with no margin for error needs to actually use the spec sheet, but it's still usually in that range.
The only film I've seen with failure so bad that adding time didn't work perfectly was Polaroid pos/neg.
It screws it up fairly modestly, but in the slide-film world of no margin for color correction you did have to filter.but it screws up the colour as well, because the three layers in the film are not affected equally by Reciprocity Law Failure....
Sure it does. That's why slide film spec sheets included filtration specifications in their reciprocity tables..... and the use of colour correction filters doesn't help, either.
Trivially. It's nowhere near as big a color shift nor light loss as the two-stops-for-tungsten that's all most folks have ever filtered for.They further reduce the light entering the camera.
Completely wrong.It is a lose-lose downward spiral situation. The only way out of the cycle is to add more light .
No, with digital long exposures you get noise even when your exposure is perfect.The failure of Reciprocity Law doesn't happen with digital, which is a blessing, but with long exposures we tend to get noise instead.... (which could be considered analogous to loss of sensitivity, since we also get noise when underexposing.)
Seriously, medium-long night exposures are the one thing I still prefer film for. Most situations patience is all you need to get around reciprocity failure. Noise and stuck pixels in digital long exposures are impossible to completely fix.
