Bill Janes
Chris,Hello Bill,However, this MTF refers only to the lens. For the MTF50 of the
printed picture, we need also to take into account the MTF of the
sensor and printing device, and this is not done in Mike's
analysis. The MTF50 of the total system would be lower than 49
lp/mm and his print might not have the required resolution of 4
lp/mm. To take these factors into account would require some pretty
complex math involving Fourier transformation and convolutions as
explained by Norman Koren on his web site.
http://www.normankoren.com/Tutorials/MTF.html
I agree with your doing the experimental approach to getting a good
MTF of your system, but let's get your math straight here. If you
have the MTFs of each independent component in your system (lens,
sensor, printer), then the total system MTF is just the product of
each individual MTF. This is the advantage of working in frequency
space; now, getting the individual MTFs of each component is
another story!
Take care,
Chris
You raise a very valid point. The Imitest experiments give an effective MTF50 for the combination of lens and camera, but I have no way of determining the MTF of the printing device. Udoubtedly, even the best printer would degrade the MTF to some degree, but I would hope that a reasonably high end digital printer such as the 400 ppi Noritsu QSS-2901 would maintain most of the image detail.
As Norman explains on his web site, before you do the multiplication you have to use the Fourier transform to convert the data into the frequency domain, multiply the components, and then convert back to the spatial domain with an inverse transform.
This is completely beyond my capability, but the point of my post was that one must consider MTF beyond the lens component.
Apparently, the old formula 1/R = 1/Rl + 1/Rf + 1/Rp, where R is total system resolution Rl lens resolution, Rf film resulution, and Rp printer resolution only works for MTF of 10% or less.
As the Leica expert Erwin Puts points out on his web site 4 lp/mm at 15x magnification on the paper is difficult to achieve even with a Leica, the best Leitz lenses, and high resolution black and white film. His site contains some interesting insights, but he still uses the old formulas!
http://www.imx.nl/photosite/technical/highres.html
For field work focusing error,camera shake and subject movement probably are the most limiting factors and it remains to be seen how much our photos would be improved if we switched from a D70 to a D2X.
Bill Janes
