Photobug197965
The size of the diffraction is related to both diaphragm size and distance between diaphragm and image plane. But if the aperture blades don't move back as the back of the lens, then this point is moot. Further, it's hard to predict how the diffraction will be, with glass element behind aperture blade.No. diffraction isn't caused by position, it's caused by the size
of the opening light is going through, which is the aperture.
Moreover, the aperture blades aren't at the back of the lens, so
even if position were a critical element, it wouldn't apply here.
AFAICT, the EF-S lenses I have all have nodal points and aperture
diaphragms in about the position you'd expect on a non EF-S lens.
I guess. But we do see some correlation between onset of diffraction limit and pixel density.First, as Bjorn points out further in the thread, all bets are off
with digital. On top of everything else, we have another lens in
the light path (the microlenses). There's a Nikon patent that
attempts to describe some of the interaction of what happens in the
light path and diffraction is mentioned tangentially in it. The net
is that the nice clear relationship we used to have between
aperture size and diffraction effects aren't so clear anymore.
Yes.But beyond that, people are being deceived by the numbers. They see
12mp versus 6mp and assume that the former is "twice as good" as
the latter. Since these extra pixels are spread in two dimensions,
the resolution uptake is not 2x, but more like 1.4x. But it may not
even be that. Why? Because we've got microlenses, image circle
effects, and antialiasing filters to consider (and of course
demosaicing and JPEG rendering engines, and noise reduction
routines).
I have no doubt about this.On paper, for example, the Kodak Pro SLR/n ought to be a winner. It
doesn't have an antialising filter or microlenses and it's got 14mp
at full frame. Unfortunately, it doesn't resolve to expectations:
the noise reduction clips detail visibly, it has signficant
side-to-side issues that are resolved with software adjustments,
and don't even get me started on the JPEG engine. Most of the
Nikkors I work with are a little softer in the corners (a much more
visible problem than diffraction).
Sometimes we SHOULDN'T bother spending more for a camera with
higher pixel count. The D2x, however, is not one of those.
Photobug
