Hi
I am using a pocketwizard in the hot shoe of my R5 (mk 1) to remote trigger another camera. However, I can only get it to work in mechanical shutter mode. Is there any way to trigger the hotshoe in ES mode? I am not looking for any flash functionality, just synchronised triggering of two cameras.
R5 doesn't support flash in ES mode. The sensor readout speed isn't fast enough for flash sync to work. There is no independent hotshoe based triggering system built into these cameras, so if you want to trigger multiple units, you should look at a system that does that specifically
The only cameras in canon lineup supporting flash sync are R5 II, R3 and R1 - basically those with fast enough sensor readout speeds
I am not using it for flash. The pocketwizard in the hotshoe is connected to another powetwizard that triggers a second camera. So I do not need any flash sync functionality, I just want it to trigger the pocketwizard signal. But I would not be surprised if it is not possible (due to the reason you mention).
Devices using the hotshoe for shutter trigger sync piggyback on the fact that the flash sync is accurate enough to work for the trigger use case. So yes, as you said, it won't work for the same reason, as the hotshoe doesn't get any signal at all. If it cannot sync a super fast flash to the shutter, it will be hard to sync another shutter to it.
PW themselves suggest using a cable trigger for such cases. Is it possible to hook up PW to both cameras cable release ports and then trigger externally?
