I own and have used several R5 Mark I bodies for some time. Yesterday, I acquired an R5 Mark II and am puzzled by a low volume sound coming from it, while it is turned on, that sounds like air flow from a fan. I have not heard this sound at all from the R5.
For each camera body, I've used the RF 70-200 f/4L lens with the image stabilizer switched on (and off). The sound from the R5 Mark II occurs as soon as it is turned on and it doesn't matter if it is at idle or actively focusing. (Neither camera has a battery grip installed).
Also, when I turn off the R5, I can hear the sensor cleaning mechanism operating and the shutter closing before it is fully off. With the R5 Mark II, there is no sensor cleaning noise (I do have it set to operate at shutdown), only the faint "fan noise" and then the shutter closing.
I'm not aware from anything I've read that the R5 Mark II has a built-in cooling fan.
Have any of you experienced a similar behavior from your R5 Mark II bodies?
