Hi! Thanks so much for your response. I'm not sure I'm clear on this though -- my understanding was that at say DR 400, and an ISO of 800, the camera raw file would be shot at the base ISO of 200 (it would be metered for ISO 800 but the shot would be recorded at ISO 200).
The problem is with "...shot at the base ISO of 200". It's not precise, and I wanted to point out that fact. When the ISO is set, several things are affected. One is how exposure parameters are calculated. Another one is what amount of analog amplification is used. Another one is what amount of mathematical manipulation of the raw data is being performed. Another one is how much noise reduction is applied, etc.
The DR setting affects only the amount of analog amplification. So, your statement should read "... the camera raw file would be obtained with the analog amplification of that of base ISO of 200".
This experiment will confirm:
Set the camera to ISO800, then take three shots with DR100, DR200, DR400 resp. and check the raw data. You will see decreasing intensities for the same exposures, because the amount of analog amplification is different while the amount of light falling on the sensor was the same.
However, when you look at the SOOC-JPEG file, they are all bona-fide ISO800 images when generated with calibrated equipment and viewed under reference conditions. They will all look different and may even appear darker with increasing DR setting, but the midpoint is preserved, and that is what determines the assigned ISO.
The fact that the raw is at -2 EV enables the preservation of the highlights; then the shadows would be digitally amplified to recover detail etc (but at the price of some noise)...
What enables the highlight preservation is the reduction in analog amplification.
There are basically three points where clipping can occur:
a) at the sensor level when the capacity of the sensor is exceeded. Only a reduction in exposure can help here.
b) after conversion to digital numbers during ADC. A reduction in the amount of analog amplification will help here, and that is the spot that the DR modes address. Note that the mechanisms implemented by Fuji (and similar ones from other manufacturers) provide a unique way for the JPEG shooter to address this issue. It cannot be recreated in any other way. The raw shooter, on the other hand, would not have to rely on that mechanism.
c) during processing of the digital numbers written to the raw file, e.g., when a certain manipulation leads to values that cannot be represented by the chosen working format (e.g., values of greater than 255 would be truncated to 255 in 8-bit JPEG).
One comment here: ISO is only relevant with respect to images generated from JPEGs viewed with our eyes. It does not apply to latent images (e.g., a JPEG file), nor does it apply to raw data. When you deal with raw data, pretty much the only ISO aspect that is relevant is the amount of analog amplification the setting represents. This is where the DR settings come in. They are basically "analog-amplification-compensation", not exposure compensation.
So my question was if LR recognizes the DR 400 setting of a Fuji Camera, and if so, does it simply increase the RAW file by +2 EV across the board (i.e., the user would have to go and play a lot with the sliders), OR, does it tone-map correctly such that the shadows are amplified but the highlights aren't touched? Thanks again...
I think it is pretty clear that LR doesn't handle the DR directives properly.
