peterharvey
Leading Member
- Messages
- 930
- Solutions
- 2
- Reaction score
- 274
I am interested in full frame, and would love an alternative to a big heavy dSLR FF, so I did some research on the Sony A7 II mirrorless FF.
Here are two very good unbiased videos discussing the pros and cons:
Pros:
1) Size and weight is fantastic, because we don't always want to lug around a big heavy dSLR.
2) Very good Sony FF sensor.
3) The lens focuses very smoothly and quietly during video [though the focusing is no longer instant].
4) 5-axis image stabilization great for still images.
Cons:
1) Very poor battery life, typically 1 battery lasts 1 hour, so this particular owner had to purchase and carry 5 batteries around in a "glasses" case.
2) The fast lenses eg f1.4 are huge in size; virtually the same size as the equivalent fast lenses on dSLR's.
3) Rear 3.0" LCD needs to improve.
4) Interface improvements needed [controls and buttons].
5) 5-axis image stabilization works poorly for video.
The author anticipates that it will take another two generations before mirrorless can replace his dSLR.
Thanks to this author, I will hold off my purchase of the current model Sony A7 II mirrorless FF.
I would hate to dive in and purchase an A7 II, and then spew and ***** about it.
Sounds like currently the A7 II is best suited for small casual use with a small number of shots, and no requirement for fast lenses with wide apertures. Because heavy shooting will require the owner to purchase and carry around half a dozen batteries, and the fast lenses eg f/1.4 on this Sony mirrorless FF is virtually the same size/weight as a dSLR fast lenses, so this defeats the purpose of buying mirrorless FF. No wonder Sony doesn't make any native/legacy zoom lenses with apertures larger than f/4.0.
Also sounds like if one is really keen on compact interchangeable lens, then one should go for mirrorless micro 4/3, but in this particular instance, I'm personally after compact interchangeable lens with full frame. So perhaps at the present point in time, there is merit in holding onto traditional dSLR FF, and then "complementing" that big/heavy dSLR FF with a mirrorless m4/3 for compact interchangeable travel, thus purchasing both dSLR FF and mirrorless m4/3; one for outright overall quality, and the other for compact travel...
Pros:
Cons:
