From my understanding that adjust the amount/saturation of color, but not the temperature/tint. Correct me if I'm wrong.
Hi Alex,I noticed the difference of color temperature of EVF vs LCD on may X-T2.
The LCD is significand "warmer" (e.g. yellow/green tint) compared to the EVF (which is more neutral/ cooler/bluer/magenta)
I called the Fujifilm-Service of my country and I got to talk to an real expert (instead of an simple call center agent. As I side note: I am an engineer myself...So I am sure I was talking to someone with expert knowledge)
First information:
- EVF and LCD is calibrated during the manufacturing process.
- Each camera gets there own individual calibration values written during manufacturing.
-> So every X-T2 should have perfect calibration after manufacturing.
Possible "user" irritation:
- The EVF-brighness in auto-Mode may lead to an difference
So try to manual set the brightness similar of LCD and EVF according to your ambient light (maybe comparing the LCD to EVF in bright sunlight is not the best way...)
Of course EVF and LCD use a different technology. So a slight difference is to be expected.
However:
Even after adjusting brightness and saturation of both displays in my X-T2 still the COLOR temperaturestill varies. The LCD is still a lot warmer.
Recommended action from fuji-service:
If the LCD and EVF still differ in color temperature significantly then you should send the X-T2 in to the fujifilm-service center for a simple check.
Fujifilm can measure the color tempreature of both LCD and EVF. If necessary fujifilm will then write new calibration values to your camera.
Hope this helps someone
Alex
I can recommendet the Fuji Service in Germany.Hi Alex,
I too notice that the LCD is a lot warmer than the EVF. I called Fujifilm repair service in USA and they've never done any calibrations as a repair. Which Fujifilm service center did you call? What was the phone number?
Thanks,
Alan
Yep. Same here: My X-T2 is more green/ yellow than my X-T10 on LCD.
