Why not more IBIS?
Why don't more brands have something like IBIS? After more than 2 years I'm still awed every time I take an indoor shot with my E-M5, even of people, at 1/15 of a second ISO 200, and get great results. Sony's is moving away from the Alpha serious which does have it and toward the e-mount which doesn't. Pentax still has it and I respect them for it. But Fuji, Nikon, Canon, Panasonic, not on the horizon.
Even if the Fuji X-T1 is an amazing camera, but who cares if one is forced to take photos at 2 or 3 f stops higher ISO than I'd have to with the OMD series. I'd rather have my E-M5 or if I was going to earn more money from photography, buy an E-M1. I'm aware that IBIS doesn't matter with say photography of football at night or race cars, requiring high shutter speeds, but it helps in more situations than I expected.
The reason Panny won't abandon OIS is because they're a much more video oriented company than Oly. And IBIS sucks for video.
That's a typo, right? I am sure you meant to say that OIS is worse for video (as it is by comparison, at least as currently implemented).
Wrong. If we were to compare just OIS and IBIS, OIS would be better. Oly does a combo deal, adding DIS to their IBIS. As far as I know, there's never been any Oly implementation of video IBIS that hasn't also included DIS.
I realize that some people may believe that Oly IBIS is buttery smooth for video,
Well, regardless of how it is achieved, Oly stabilization actually is "buttery smooth" for video.
Using methods that introduce artifacts into the video.
but what they don't realize is that Oly has implemented a form of DIS on every MFT camera where they've done IBIS for video. So, when you see Oly's IBIS in action on YouTube, you're seeing a combination of IBIS and DIS. Note that I don't believe this is done for stills, as far as I know.
What makes you think that it is a combination of DIS and IBIS?
Even if Oly is using DIS with IBIS, why do I say it sucks, you might ask. Because IBIS is a much greater energy hog than OIS and will suck much more power when used continuously.
Do you have any evidence of that or is it just speculation on your part?
Yes. People that I've talked to that have used Oly cameras for video with IBIS have always told me that the video is cropped when IBIS is activated (as compared to no IBIS). If I'm wrong then let me know.
Cropped video to achieve stabilization means that DIS is being used. Not maybe but definitely.
This is precisely the reason IBIS doesn't run all the time (only when the shutter is pressed) while OIS does.
It's a good idea to turn things off when they are not required. Why doesn't Pany do the same?
Why no option to keep it running all the time? Very strange if you ask me. I've theorized that it's either due to excessive power consumption or possibly heat generation.
There's simply no plausible reason not to give the user the option of leaving it on continuously unless there were a technological limitation.
And this jives with my understanding of IBIS and the energy requirements of moving the sensor (vs. moving a lens element).
And why would Panny give the option of only activating OIS when you press the shutter. Sounds ridiculous to request it to me, as I see no benefit to it (given the minimal power requirements of OIS). Panny gives you the option of turning on/off the OIS.
And it's very probable that Oly uses a less energy hogging form of IBIS when video is engaged (hence the reports of less noise from IBIS in video than stills mode).
Yes, they do. Less energy is required for video stabilization than for stills since the objective is different. With stills, you want each frame as sharp as possibles. Hence IBIS has to move fast. With video, the primary objective is to eliminate the jerkiness between frames. Hence IBIS can move at a more leisurely pace.
Sounds dubious to me. Some would say grasping at straws. You want every frame as sharp as possible with video as well.
Why does IBIS suck so much more power, you might ask. Because the sensor element is often much larger and heavier than the lens element that has to be controlled, hence more power consumed to move it (and also slower and less responsive movements of the element).
Yes, I have evidence of that. Aside from my sources, I've actually taken apart some old gear to have a look at it.
That's brings me to another point.
IBIS is less effective than Power OIS (by about 0.5 to 0.8 stops).
At least some implementations of Power OIS (as opposed to Mega OIS) were, when tested while shutter shock was still a problem. Below you find what I think is the latest list of the results from Lenstip/optyczne.pl that I have compiled:
http://www.dpreview.com/forums/post/52944375
And that difference will likely increase as the focal length is increased. The reasons are two-fold. First, the lens element being controlled will likely be much smaller than the sensor, so it can be moved quicker. This becomes more important as the focal length increases, because hand shake is amplified at greater focal lengths. Also, the compensatory movement of the lens element (OIS) can be magnified on the sensor, thus providing greater shake compensation than the actual motion of the lens element. This obviously can't be done with IBIS.
Here I have some new and interesting facts to offer as a counterpoint to your speculations. As we both know, the real effectiveness of the different stabilization systems couldn't really be tested with longer FLs in the past due to shutter-shock problems. Below 1/250 or 1/320, shutter shock spoiled the fun regardless.
With the electronic first curtain shutter (0-second anti-shock) now available on the E-M1, E-M10, and E-P5, we are finally in a position to do the test and of course I did it. I tried the 100-300 at 300 on my E-M1 and ... my preliminary results (I have still to do more extensive testing) indicate quite clearly that the E-M1 IBIS is significantly better than the 100-300 OIS once the shutter-shock problem is out of the way. At the same shutter speed, the number of keepers is clearly higher with IBIS than with OIS. And the lowest speed worth trying is lower with IBIS as well.
Here's a modest example of what I am talking about. This is a 100-percent crop shot with the Oly 75-300 I am now trying out as a replacement for the Pany 100-300. Hand-held with IBIS at 300 mm and 1/10.
Aside from the fact that I see no actual comparisons here, you'll forgive me if I actually wait for an objective comparison. Also, it's important to note that the 100-300 is an old lens with mega OIS.
So, why doesn't Panny do IBIS along with OIS. I believe this has everything to do with competition. If Panny were the sole player in MFT, I have a feeling they would. But, for now, I believe they want to protect their lens OIS. And I don't blame them
What exactly do you mean when you say they want to "protect their lens OIS"? What specifically is their objective? And how does abstaining from IBIS help them accomplish that?
If someone is a Panasonic body loyalist and Panny provides in body stabilization for all their cameras, there's less incentive to buy Panasonic lenses. For me, being a purist and understanding the benefits of in lens OIS, I would still buy the Panny lenses.
But others would believe that stabilization is stabilization and just go with whatever.
In summary, it's the limited interests (no video, etc.) on this forum that are the reason so many people don't understand why things are done the way they are. No offense.
Although you are right that most people on the forum are more focused on stills than on video, that certainly doesn't prevent them from understanding what's going on with regard to stabilization systems.
You're right. It's ignorance of other aspects as well. :)
I look forward to your response Anders. :)
Glad to hear that. :-)
"Aside from the fact that I see no actual comparisons here, you'll forgive me if I actually wait for an objective comparison. Also, it's important to note that the 100-300 is an old lens with mega OIS."
That is a major flaw with OIS your stuck with old technology in your expensive lenses even if you upgrade the body unless Panasonic gives in and implements some sort of IBIS. Personally I think Panasonic makes some great glass and cameras but OIS wasn't one of their better ideas IMO.
http://www.flickr.com/photos/90891174@N04/
That's utter nonsense. And I bet if you think about it for a second you can figure out exactly what I'm going to say.
When you buy an Oly or Sigma lens, you have no OIS to begin with, and those lenses are just as expensive as Panny lenses. So, what do you get with Panny power OIS lenses? You get 3.5 to 4 stops on every body you ever own. Will 3.5 to 4 stops ever become outdated? I suppose it's possible that we could see 5 stops at some point in the future, but does that make a lens with just under 4 stops "outdated"? Hardly.
It's the Oly and Sigma lenses that have nothing else to offer. Now, one could argue that they their stabilization systems aren't going to become outdated, but I think you see the flaw in this argument.
Also, new bodies are usually more expensive than lenses. But if you want to stick with the assertion that the lens is the thing that's going to stick with you, then why not go with one that gives you value added to begin with.
OIS?
With any and every lens?
Not required.
Slippery slope. Is AF required? Is usable ISO past 200 required? Are digital cameras even required? People took some very nice shots with film after all.
The answer to all of this is no, but it sure is nice to have, just as IS on every lens, regardless if its a native mount lens or a vintage MF lens is very nice to have.
Some say IS isn't required on wides, I beg to differ, I can take sharp shots down to 1 1/3rd seconds with my EM1/7-14mm, quite reliably. What is or is not required is very subjective to each person, there are no absolutes here.
Interesting read.
You must be steadier than a concrete block. ;)
You say you can take sharp shots down to 1 1/3rd seconds with your EM1/7-14mm. That's amazing.
But, are they tack critically sharp enough to say, print to 16"x20"?
Please reveal your steady handheld technique.
So, how about sharing some of your very best shots taken with that shutter speed and lens? :)
On the contrary, I have relatively shaky hands actually. I haven't made huge prints from any shots at speeds this slow (but I don't make large prints, or prints at all, very often). Critically sharp is of course going to be subjective, perhaps usably sharp is a better description in this case. No, every shot that I take at 1 1/3rd isn't sharp, but its reliable enough to get keepers with good technique. My technique is pretty basic, just make sure to hold the camera as steady as possible, and shoot a short burst of 3 or so, usually the middle one is the best.
1.3 seconds is fairly extreme, its not a shutter speed I shoot at all the time or anything, but it is possible to get usable shots handheld at that speed. In real world use it means that when I don't need to freeze action, I can get away with a lower shutter speed, which means lower ISO, and better image quality.
It also means I only ever carry a tripod when I'm doing bracketing or extremely long exposures (over 1 second). Down to 1 second or so I'm confident I can get what I need with wider lenses like the 7-14, and 0.5 seconds works with lenses like the 25/1.4. This is great if I'm shooting still life in low light, do not care about a bit of subject motion or want to purposely blur subject motion. With crowded streets I often prefer to have some blur rather than a perfectly sharp shot of random strangers, and for things like creamy waterfalls its very useful. When I have the option, I would rather drop the shutter speed and keep the ISO low to keep noise down and DR high, especially with M43 sensors.
Here's a couple at 1.3 and another at 0.6.
I was encouraged to try shooting this slow after reading Robin Wong's review, in which he was able to get decent shots down to 1.6 seconds. See for yourself: http://robinwong.blogspot.com/2013/09/olympus-om-d-e-m1-review-introduction.html
Beautiful shots.
The EM1 IBIS with 7-14, and 25PL seem to work well together.
I thought I read somewhere online the 7-14 is not a recommended lens for Oly cameras because with that lens SOOC results in purple oblong artifacts blobs around specular highlights like street lamps.
But I don't see those kind of artifacts in your pics. Were they present SOOC, and did you correct them, if any, in post?
And thanks for the tips and link to R. Wong's blog.
Thanks! The 7-14mm does have some nasty purple flaring on the EM5/EM1, I don't think it shows up in these shots because its not bright, direct light sources, both of these shots the light was very low, even the last shot where it looks like the upper section is glowing was overcast, ambient daylight.
I did the rear filter mod for the 7-14mm now which seems to have taken care of the purple flaring, though I haven't had a chance to really put it to the test yet.
No it's not utter nonsense. If I buy an Olympus body I can get image stabilization with any lens I purchase. Can you? There was a thread on this forum sometime back where the reviewer got good results from an EM1 at 5 stops. Panasonic lenses by the way are usually more expensive than Olympus lenses and definitely more than Sigma at least in the focal lengths I've purchased. However some of them have better image quality than the corresponding lenses from Olympus and that could be part of the reason but OIS is part of the price. The reason I got into Olympus is I can use any lens and enjoy image stabilization it gives me more choice. So why did Panasonic implement IBIS on the GX7? Probably to give their customers more flexibility in lens choices. I'm not saying OIS doesn't work or it is crap. I just don't want to be stuck using lenses from one manufacturer. If I wanted that I could have bought a Canon, Nikon or Sony.
A user got 5 stops with the E-M1? Okay, so which am I going to believe, this highly educated user who gets 5 stops or the scientific tests at lenstip.com, where they got 3 stops. Hmmm.
Tough call. But I think I'll go with lenstip.com.
You know you can also use your Olympus IBIS on Panny lenses just as well as you can with Oly lenses. You're not forced to turn on the OIS if you don't want it. That's the versatility of lenses with OIS. You can use it or not, depending on what you want. Can your Oly lenses give you the choice of having stabilization on an unstabilized body?
Again, it's a ridiculous argument and really a no-brainer when it comes to lens choice. Buy the lens with stabilization an choose whether to use it or not.
From my experience, even with OIS, Panny lenses are very competitive in pricing with Oly lenses. But, if you've had a different experience, let me know.
Because, who wants to look at a shaky image when composing a shot. This is especially true of telephoto lenses. It's distracting and annoying.
There's a setting to enable IBIS during half-press of the shutter button (5-axis IBIS at least). I think that's perfectly reasonable. I wish the GX7 worked the same way.
PhotoGrok: http://www.haplessgenius.com/photogrok
Yes, I know that. That's what I meant by it's activated when you press the shutter button. Maybe I should have said "half-press".
Anyway, I want to emphasize again that, IMO, it shows a lack of critical reasoning/thinking to not question why it doesn't run continuously and why you don't have the option to enable it.
To say it's "good enough" is not good enough in my book because I know for a fact there are plenty of people (myself included) who don't want to look at a shaky image until I half-press the shutter.
And if you don't think Oly knows this, you're deluding yourself. If you think they did it just because it's "good enough" and there's no technological barrier, you're again deluding yourself.
All I'm asking for is just some critical thought on the issue. Is that really too much to ask?
I assume IBIS is not on all the time to save battery life but I'm not an Olympus engineer. Either way, it's basically irrelevant to me as the current functionality is perfectly acceptable. "Good enough" never entered my mind as I don't even recognize it as an issue.
Clearly you're troubled by it but the great thing is Panasonic's OIS works fine on Olympus bodies. I still use IBIS when composing as I find it provides a more stable image.
I'm troubled by it because I use video and it's not suitable for video. I also wouldn't like it if I had a 300mm lens or larger (600mm+ eq. focal length) and I didn't have a continuously stabilized image. If you're under 100mm, it's probably okay, but when you get into the higher focal lengths, you'd want it stabilized all the time.
Nice enough to offset the price difference, though? Canon and Nikon want you to think that, so they can charge extra, and so they aren't seen to be using dated technology.
It is usually the cheapest and the slowest lenses that have VR (18,55, 18-85, 18-200, 18-300, etc), and not the faster and more expensive ones. To the exception of 70-200/2.8, which is also a somewhat better alternative to less expensive 80-200/2.8 - and I suspect the price is more related to the optical design, rather than addons.
Let's just say it's extra sweet to have the 5 axis IBIS available for anything I can mount on the OMD's.
It is a small camera, which will easily pick up vibrations from hands.
If you go to the most expensive Nikkor lens and count down along the line one by one by price, you would go through at least ten lenses all with VR before having any hope of seeing one without.
A fully comparable pair is difficult to find, but the Canon 70-200/4L comes in two versions, with and without IS. The price could be double/half depending on the market they are sold in. The IS feature costs the complete non-IS lens, and it's actually worth it, I think.
http://www.flickr.com/photos/xiafei/
You are right, starting with 200/2, then 300/2.8, 400, 500, 600, and 800, .. all have VR. I did not know that.
True. I was under an impression only the less expensive lenses have VR.
Hmm, that makes sense. Thank you. I guess once manufacturers chose one route it is hard to change. It certainly keeps me from looking to jump ship to another brand, well that and accumulated m43 glass. I think, yes I can get maybe maximum 1 stop better noise (though worse DR) with the best of the best, but I'll be shooting everything at 2 or 3 stops higher ISO so what's the use.
No, IBIS makes no sense on a camera with an OVF. Unless you like making tele shots with a jittery viewfinder.
Apparently, that didn't prevent Konica-Minolta (Sony A-mount), Olympus and Pentax from going with IBIS rather than OIS for their DSLR systems with OVF. And why did Fuji, Panasonic, and Sony (E-mount) go with OIS for their non-OVF systems?
I don't know much or anything about Konica-Minolta (how are they doing these days?)
I realize you don't know much about anything but Konica-Minolta is known as Sony these days.
No, I don't know much about anything, but I know your rudeness isn't worth any more of my time.
As you make your bed, you must lie on it.
Olympus also used IBIS on its later DSLR's for the obvious reason that they had a collection of unstabilised lenses that were not going to get a make over in stabilised form.
Exactly. They are businesses and if that is all they had to work with, then they went with what was most cost-effective overall for their brand. Had they been able to start from scratch, OIS would have been the easy choice for a better camera.
Apparently there are plenty of people who don't 'get' why IBIS is not a great choice for a DSLR anyhow. They see 'Oh, all my lenses will be stabilized! Great!' and that's all the thought they give it.
I am one of those people who didn't get why IBIS is not a great choice for a DSLR. The reason I didn't get why it is not a great choice is that it is. So I shot Pentax before I moved to MFT.
If I see my image jumping around the viewfinder, while hoping it will be ok after all, I am not sure I would really be looking forward to it. I would say, fine, this time it worked, but so what.
I think one of the other reasons for stabilizing smaller cameras is that they are usually taken anywhere, and the top quality final output can be easily replaced for good enough. Or put it differently, where I need it precise, I don't think stabilizer would help. Where good enough is the ticket, I would not be waving my camera there. So kind of works out for all at the end.
There could be one hypothetical difference. With OIS you can stabilize the viewing as well as the shooting in an SLR. IBIS could stabilize viewing through liveview only and not the OVF.
On the other hand, viewing needs stabilizing more with EVF/liveview than OVF, so the difference may be something nice to have but not necessarily always essential, until you get to very long lenses and the AF points become difficult to be pointed precisely without stabilization. With EVF there's the additional problem of dizziness and motion sickness which stabilization eliminates.
That's not just a hypothetical difference. It's a real difference. And I don't dispute that having the OVF image stabilized is an advantage. It's just that in my experience, it's a pretty minor advantage and certainly not enough to offset the advantages of IBIS compared to OIS.
As I mentioned, I used a Pentax DSLR before moving to MFT. And the reason I chose Pentax over Canikon is that it offered IBIS. I was well aware that I lost the ability to have the OVF stabilized. But that didn't bother me much even when using my Tamron 70-300 at the long end.
Live view was not yet available when I bought my Pentax. With EVF/live view, stabilization becomes more valuable due to another asset: magnification.
Yes, I remember now that you said you have trouble with that. Fortunately, I have always been more or less immune to motion sickness. Probably due to some defect in my sense of balance. ;-)
The surprise for me was Nex. Sony (then Konica Minolta) pioneered the system on APS-C and all their DSLRs have it. Then they dropped it for mirrorless.
I have an E-PM2 and frankly the IS is not very good, but I understand that E-M5 and later are much better.
Stabilization systems are now tested by CIPA. For the E-M1, the results is 4 stops. What are the corresponding results for Panasonic OIS?
http://www.olympusimage.com.my/products/dslr/em1/feature/04/
That's precisely the point. Why get an unstabilized body that restricts you to lenses from one manufacturer only if you want stabilization?
With stabilization in the body, there is no such problem. You have it with Pany as well as Oly lenses. If Pany bodies had IBIS, and the Pany IBIS were competitive with that of Oly (that of the GX7 isn't), lenses would be freely interchangeable without any concern for the lack of stabilization.
On the contrary, the evidence we now have suggests it is more suitable for video. As you put it, "buttery smooth".
Personally, I need it stabilized only when looking at the EVF/LCD and IBIS gives me that without any trouble. Why would I need to have the live-view image stabilized when not looking at it?
It seems you have overlooked several direct, specific requests for information in this discussion. I know that some people find inline responses especially complex and difficult to follow, so I've pruned the previous post in order to draw attention to those requests in the hopes that they'll be easier for you to spot and respond to in detail.
Please let us all know how you did the comparison. And if you didn't, how would you know which is better?
Looking forward to your response!
What are the OIS and IBIS power requirements? Got any facts and figures?
No. They don't release those and it's very difficult to measure.
By your own admission, you have no facts or figures regarding OIS and IBIS power requirements, and "it's very difficult to measure," yet you've stated unequivocally that "IBIS ... uses more power." Could you go into more detail about the evidence upon which you based this conclusion and the reasoning you used to reach it?
Which are these sources? Links please.
Looking forward to your response! Also, in addition to links to your sources, I would also appreciate it if you would detail the additional evidence you allude to above.
Exactly what old gear did you take apart, exactly what did you see and measure, and exactly what conclusions about power requirements can you draw from these observations?
Looking forward to your response (see especially the bolded excerpt, which you seem to have overlooked in your last reply)!
If Oly uses a combination of DIS and IBIS for video (as seems likely, see below), what's wrong with that as long as it produces good results.
Nothing wrong with it, but they never put it in the specs for the E-M5 and E-M1, as far as I know. And with no option to only use IBIS, we can't accurately compare the two.
We can accurately compare two technical solutions, IBIS+DIS versus OIS, and the former wins.
Furthermore, we don't know what relative contribution the IBIS gives and the DIS gives.
It would be nice to have the option to just use IBIS.
Why is that if IBIS+DIS gives better results?
Also, it's important to note that DIS can be done in post with a slight reduction in sharpness and possibly with better results, given the difference in computing power you have in real time vs with your computer. It's also something that can be added to OIS if the camera body supports it.
Well, at present it doesn't.
There's nothing inherent in IBIS that makes DIS easier to implement.
Neither of us knows. But it remains a fact that it is implemented with IBIS but not with OIS.
What artifacts specifically due to DIS are you talking about?
Digital stabilization is known to introduce artifacts, whether in real time or in post, because it's simply a software analysis of the motion. Not to mention the fact that you're doing the crop in real time.
The fact that it is software- rather than hardware-based doesn't necessarily imply that it introduces artifacts. I asked you specifically what artifacts you are talking about. You dodged the question.
Yes, video with stabilization enabled is cropped slightly, which suggests that sensor-shift is supplemented by DIS. This is also what Imaging-Resource reports in their review of the E-M10:
"For video recording, Olympus has also included a hybrid IS system utilizing both sensor-shift and digital image stabilization"
http://www.imaging-resource.com/PRODS/olympus-e-m10/olympus-e-m10A.HTM
Why would you want to run it all the time even if not required? Recent implementations (E-M1, E-M10) do in fact run it all the time when in magnified view since in that case it is indeed useful.
That's not an answer to the question I asked. The question was: Why would you want to run it all the time even if not required? When required, it either is on (because of magnified view or video mode) or can easily be turned on (by half-pressing the shutter button). Consequently, I never have to look at a shaky image when composing a shot with IBIS.
And if Panasonic feels that turning on/off OIS when you press the shutter doesn't add anything, who am I to argue?
And if Olympus feels that keeping IBIS on even when not required doesn't add anything, who am I to argue?
Perhaps in the final analysis, they found no benefit. From a consumer perspective, you certainly can't argue that this gives you any added benefit when shooting.
According to Panasonic themselves, keeping it off until the time of exposure (when they allowed that, as they did prior to the G3) increases the effectiveness of the system during exposure by 20 percent (see point 12 in the FAQ list)
http://shop.panasonic.com/shop/support-digital-cameras?support=y
the reason being that the OIS lens group is centered at the beginning of the exposure and therefore has more leeway to move in all directions.
The only benefit would be if the MFR felt it was more efficient or saved power.
With respect to efficiency, see above.
And it seems clear Panasonic felt it didn't.
So are you saying that Panasonic never makes any mistake?
I certainly see very little power savings with OIS off vs on.
And you still have not given an explanation of why Oly doesn't give the option to keep it running all the time under any circumstance you want. You certainly can't argue that this would not be beneficial.
I am certainly arguing that it wouldn't be beneficial. What would be the benefit of keeping it running even when not required?
If you do, it's a clear demonstration of bias on your part.
Not unless you can show that it is beneficial to keep it running when not required, which you evidently can't.
The fact that you would fault Panny for not giving the option to turn on OIS only when the shutter is pressed yet you don't fault Oly for not giving the option to turn on IBIS all the time is a clear indication of bias, and you'll have a hard time convincing me or any objective reader otherwise.
See above.
And I stand by my assertion that there is probably some technological reason behind it.
For example the desire not to waste power, which is a good thing, isn't it?
It does run continuously when that's beneficial. See above.
Uh-huh.
So this is all you can muster in the way of argument?
Fine that you recognize that we have no information on that.
Actually you don't inasmuch as that sometimes conflicts with the desire to eliminate jerkiness across frames, which is of greater importance perceptually. But possibly, Oly's combination of sensor-shift and DIS helps them accomplish both.
Of course it helps with the shake, but DIS is known to negatively impact image quality in other ways.
In specifically which ways is DIS known to negatively impact image quality and where's your evidence?
To see how effective it can be, again, take a look at the Sony action cam, which only uses DIS. You can walk with that and have a buttery smooth image. When something is that smooth, it's often clear that DIS is being used. But, again, it comes at a cost. And it's always nice when you have the opportunity to shut it off and just go with the mechanical stabilization.
And, again, no opportunity to really compare IBIS to OIS at wider angles. However, based on what I've seen, OIS performs better than IBIS at telephoto FL's, even with DIS on Oly cams. DIS works better at wider angles, and it shows in Oly's implementation.
What specifically is it that you have seen that makes you think OIS performs better than IBIS+DIS at telephoto FLs?
None was intended. I just illustrated that IBIS can help me manage some six EV below the 1/EFL rule at 300 mm. I haven't yet managed to accomplish that with OIS.
A single shot proves absolutely nothing.
The crop wasn't meant to prove anything. It was merely meant as an illustration.
And I've come to the conclusion that we need unbiased laboratory tests when it comes to these issues. Otherwise, we get unscientific statements such as I "managed six stops", which is meaningless.
In exactly what way is the statement meaningless? I have yet to manage the same with OIS.
Unlike you, I have no problem with impartiality. If OIS were better, I'd say so and use it whenever possible. If you think I am trying to hide anything, why would I have compiled the list I linked to above, showing that Power OIS is better than IBIS as long as shutter shock is still in the reckoning? And why would I state, as I have many times over, that, with my E-M5, I prefer the 14-45 OIS over IBIS since the OIS of that particular lens (not others) actually helps counteract shutter shock?
I think you are biased, as I mentioned earlier. The fact that you see nothing wrong with Oly not giving continuous stabilization yet you fault Panny for not giving the option of just turning on OIS when the shutter is pressed is a strong indication of bias in my book.
It's a nonsensical stand as there are clear and unequivocal benefits to continuous stabilization to anyone who would spend a second thinking about it (lack of shake when composing for one). While the thing you fault Panny for, I have yet to see you provide one lick of evidence that it provides any benefit in terms of power or effectiveness. And absent any laboratory tests demonstrating a benefit, there is simply no benefit to a shooter in a general sense from having this. In other words, the thing that you fault Panny for can only demonstrate benefit under laboratory conditions. It's not something that someone would ever put on their wish list, as there's no clear benefit to it (under any circumstance, as far as I can tell).
All of that has already been dealt with above.
Is there any other Pany lens than this that goes to 300 mm?
I don't know.
Well, the rest of us know that there isn't.
So you mean that Pany sticks to OIS in order to limit competition on the lens side? That may well be, but it is hardly a convincing argument to those of us who are on the consumer rather than manufacturer side, is it?
No, they stick to OIS because it's a technically better system. But decisions are often financially motivated and, in order to protect their technically better system, they have to make compromises, IMO. Note that this is all conjecture on my part as I'm not sitting in on their boardrooms.
If it were indeed technically better, no financial motivations would be needed.
IMO, OIS and IBIS have their benefits and disadvantages. The only disadvantage of OIS however is the fact that it doesn't work on all lenses. But OIS is a technically better system than IBIS when a lens has it.
Certainly not as judged by my tests with the 100-300 and OIS versus E-M1 IBIS.
Noone denies you the privilege of buying whatever you want. As a non-purist, I simply prefer to use what is best rather than most pure.
I'm exactly the same. I meant, as a purist, I stick to what I know is best, rather than go with unscientific marketing hype. That's why I stick to OIS when available.
So we simply disagree on what is best. And what is best is a matter of evidence, right?
And as a video shooter and one who knows the disadvantages of IBIS at long focal lengths,
On what basis do you know the disadvantages of IBIS at long focal lengths? Where's your evidence?
I don't want to see MFT go down the wrong path with IBIS only. Without OIS, MFT will be severely handicapped in some areas.
Which areas?
For most of the shooting done on this forums, I'm sure IBIS is a godsend, but the typical user should understand the very limited scope of interest of people on this forum and understand that this is the reason for the bias toward IBIS.
See my question immediately above.
A third option is to believe, as I do, that different stabilization systems are different means to the same end and then choose the best means to that end.
You're right.
Thanks!
As well? I didn't say anything about ignorance.
http://imaging.nikon.com/lineup/lens/index.htm
