Mike CH
While that is true enough, I am not quite sure what prompted you to bring that up as a response to what I wrote?You can't get 3D viewing from one ocular. That is why binos look more like what we see with our eyes compared to one VF.Something like that.However lenses that have a larger image circle will inevitably have to be larger as well.Good points well made.You’re frustrated for two reasons.
First, you’ve chosen to compare lens sizes betwee APS-C and FF cameras. Not a good idea...
Second, you’ve bought into the senseless claim that ML must by necessity make everything smaller. This is a baseless claim. ML can make bodies smaller due to the abscence of the mirror box. The absence of the mirror box enables a shorter flange distance, which means that lenses shorter than say 40mm can potentially be made smaller. All other lenses are hardly affected.
Additionally, one driver of lens size that isn’t going away is that (many) photographers expect better and better corrected lenses. This means more complicated designs, meaning larger lenses.
Regards, Mike
I would also add that IBIS on FF demands lenses project a larger image circle with high quality right out to the edges. Nikon would have been engineering around the limitations of the F Mount here with the image circles on its F Mount circles. This is probably why we hear that converted lenses will only have roll IBIS as this doesn’t need a bigger image circle. Z Mount removes these limitations and we should expect them to take full advantage of this in the optics they produce.
One step forward. One step back?
Or, rather, the association I get - but that’s more from the users than from the lens design - is more like “(When in doubt,) run in circles, scream and shout”.
Regards, Mike
Regards, Mike
