Nothing stops them. Maybe only the fact that they are the market leader and want to see how the merket develops. Still, they will make such camera rather sooner then later.actually the rate button is hugely popular with working pros.Well, the new Nikon is way smaller then the 5D IV and has bigger grip then the A7 and a top display. So obviously it is possible to do it in a small body.I should have stated non-1 series grip style, however i though that would have been obvious.The 5D IV is not the largest Canon camera they make, it is the 1DX II. In the past they made also larger cameras like the 1Ds and 1D line. There is only one Canon camera, that is FF and smaller than the 5D IV: it is the 6DII. And the 6D II is still bigger then the A7 III / A7r III.sure if you ignore ergonomic differences between then and falsey assume that's as small as canon can make a full frame. oh wait, it's not because that's even a 5D Mark IV image, you've chosen the largest full frame camera that canon makes and compared it to cameras that are lacking it's haptic buttons and top plate LCD and claiming similarity.The main size advantage of the mirrorless design can be seen when looking and the body and also when using wide angle lenses.There are no real size/weight savings with FF mirrorless. So why introduce a new mount to shave a few mm's off the body thickness?
Just a quick comparisson:
https://camerasize.com/compact/#682.425,777.440,654.31,ha,t
Greetings
Ivan
except the A7RIII lacks much more such as the haptic buttons across the top and a top plate LCD which dramatically increase the size of the camera. it also lacks a grip the size of the 5D Mark IV which dramatically changes the size of the camera.I compared the A7(r)iii with the 5D, because these cameras are positioned against each other in the market. The 5D IV also lacks some ergonomic aspects like the articulating screen for example.
Obviously a lot of people disagree, with your opinion about the ergonomics: we are both Canon users in the Canon forum talking about Sony. Look at the Sony again and tell me wich buttons from a Canon 5D you miss. The "rate button"?the A7 series is almost down to rebel ergonomics with a joystick added.
and then you also have the fact that the 5D Mark IV has a penta prism, and related housing which increases the size over that of an EVF and it's related optics.
but this is really an easy mental exercise.
answer this question:
what is stopping canon from making an EF mirrorless full frame camera the size of an SL2 or even smaller than that if you take into account a mirrorless has no AF, AE and penta mirror assembly?
