I have been waffling back and forth between moving to a Sony A7 or A6000, and looking at DxOMark's low light sensor rating I think I realized something kind of interesting.
First of all, correct me if I'm wrong, but sensitivity across formats is not really equivalent, and smaller sensors are inherently more sensitive than larger sensors for a given DoF & shutter speed length. I.e. if you have the same ISO, aperture diameter & shutter speed in front of two different size sensors, the larger sensor will have a dimmer exposure due to the given volume of light being spread over a larger area.
With that in mind, FF has 1.2 stops/2.36 times more sensor area than APS-C. So correct me if I'm wrong, but if an APS-C sensor is rated at ISO1000 for some low light S/N metric, a FF sensor with equivalent performance per unit of area will be rated at ISO2360 for the same metric, correct?
Well when you apply that math to the A6000 and A7 something interesting happens. The A6000 is rated at ISO1350 for DxO's 30db low light S/N test, and the A7 is rated at ISO2248. You do some quick math and realize that if the sensors are supposed to be equivalent, either the A7 should be rated at ISO3186 or the A6000 should be rated at ISO950. That's half a stop!
What's the practical impact of that? If you have a low light scene and two equivalent lenses wide open on the two cameras (i.e. the 24 1.8 & the 35 2.8), the A7 will have half a stop more noise. Yes, you will be able to bump up to a "higher ISO", but that's meaningless- you will have to up your ISO to have an equivalent picture (same shutter speed and depth of field) on the bigger sensor as it has inherently dimmer exposures than the smaller sensor.
Does this mean I won't get the A7? Probably not though I might go for the A7R as it somehow claws back most of that missing half a stop. Plus my legacy lenses will work a lot better on the full frame sensor naked than on a crop sensor through a focal length reducer. So there are other considerations to make. But my point is it might be time to change how we look at "high ISO" performance, and create a new metric to normalize it to sensor area. To really compare apples to apples ISO performance between formats you have to use a correction factor. If my math is correct it is pretty much the crop factor between the two formats squared. I.e. Sony APS-C has a crop factor of 1.536 vs Sony FF, so to compare the two you have to either divide the FF ISO or multiply the APS-C ISO by 1.536^2 (the 2.36 I referenced before which is the ratio of the two sensor areas).
This has other implications as well. A little 1/2.3 sensor at ISO100 is operating at a sensitivity equivalent to ISO3500 on a full frame. No wonder dynamic range and color sensitivities are so much worse.
Anyways I just thought that was interesting.
