The "lens can't (out)resolve the sensor" myth
It's called the Rayleigh resolution. It measures how close two point sources of light can be and still be distinguished by a lens. The value is fairly simple given to
theta = 1.22 lamda/D where theta is the angular measure, lambda the wavelength and D the diameter of the aperture which the light passes. We all know that the aperture produces diffraction which can limit resolution. However, it is the ratio of the wavelength to aperture diameter and not the absolute diameter that is important.
This is a function of radiation. A microscope cannot resolve two objects less than 1.22 a wavelength of the light source. That is why a radiation source of higher energy such as an electron beam is needed to see beyond of a standard microscope. A radar's resolving power is limited by the wavelength of the radar's wavelength. In fact two lasers of diameter D when close enough together will spread so they cannot be resolved as two at some distance. Any beam or radiation of diameter D and wavelength lambda will produce a spreading by an angle
theta = 1.22 lambda/D. It is a property of radiation independent of the lens.
So analogue or not - does not mean there no limits.
However, I think what is lost here is that a 40 MP CFA does not have the same resolution as a 40 MP native sensor. So for the question with the new Fuji one needs to first determine the effective resolution after the demosiac interpolation has been applied. That is going to result in a loss of at least 1/2 and maybe up to 2/3's. However, I expect that most people will notice an improved image quality in normal viewing at the same image physical dimensions with a 40 MP sensor over a 26 MP sensor. Pixel peaking a 40 MP and a 26 MP is not viewing at the same size, now is it.
I am considering XF 16/2.8 candidacy for the position of a wide angle for indoor video in crowded locations. Video means oversampling. So neither infrared nor pixel peeping matter to me. I am completely sure it will fit my style, my usage patterns and my IQ requirements. But the main advantage is... it is available in a silver finish! This is the point.
" I have my own understanding of the pixel peeping phenomena ... if anyone is interested, I'll find half an hour to write it down'
I am kind of curious about what thoughts people have on pixel peeping from a psychological standpoint... if that is what you were thinking of writing up.
I am meanwhile retired, at young age, so I have not time for pixel peeping :-)
Dan
All I can say is that the 16f2.8 is reasonably sharp @100% on a 12MP sensor, not sharp on a 24MP sensor. That's all I need to know
Now back from philosophy to photography. Can you please share a 24 Mpx RAF from 16/2.8 which is considered crappy by you? I am considering this lens for purchase, so very interested. Thanks in advance!
Just to be sure: I am talking about the Sony E16f2.8, not the Fuji (which I still own). The Sony I sold a long time ago when I switched from the NEX 3 to the a6000.
Thank you for the info and I apologize for my mistake - honestly I can't explain why was I thinking of specifically XF 16/2.8 but not some other lens. Probably just a coincidence.
Thank you for a clean and clear explanation!
My own personal outcome from this info is:
  • 24 Mpx sensor starts to visibly suffer from diffraction from f/8 and slower,
  • 40 Mpx sensor starts to suffer from f/5.6 and slower.
One more argument against the 40 Mpx sensor for me.
Yes, this exactly is what I am speaking about. As I see at least one single person (you) shows some moderate interest in my own vision and version, I will write it a bit later (give me a day or two please) in a separate post, Ok?
