Hi DirkHi David,
My results are without the Hard setting but using the STD setting
for sharpness always sharp as a razor so I think there must be
something wrong with the alignement of your ccd, couldn't you do
some tests on that (some suggested here in other threads how to do
that). Are you using top quality lenses, some lenses that gives
very good results with my S1 are absolutely not good enough for
using with the S2. And another thing that changed very much versus
the S1 is the sensitivity to camera shake.
With very kind regards,
Dirk
http://www.pbase.com/dievee
Pbase supporter
Thanks for your reply. I really am fed-up with the camera. If what you say is correct, why produce a camera that is more prone to camera shake? The shot I had in mind was actually taken using a tripod and the lens used was a 28-105mm 3.5-4.5D AF Nikkor. ISO 100 1/30th f4.5. The shot is usable with unsharp mask but I would have expected it to be pin sharp! I will do some tests as you recommend.
Fuji tell me to use HARD setting and to add 150% 2 and 2. I think there may be a problem with a batch of these S2's. What do you think?
Kind regards
David
