peter
I had a bad sync port and it was within 30 days of purchase and sent it back to the place I bought it which was state street direct and they shipped me a new one.
Peter
Peter
I just loaded some comparison images..
http://www.pbase.com/deluco/s2
Jim DeLuco
DeLuco Photography
http://www.delucophoto.com
http://www.pbase.com/moyses/inbox
Jim DeLuco
DeLuco Photography
Jim DeLuco
DeLuco Photography
Some folks on here talk about lack of experience, incorrect
settings, etc. That's just not the case with some of these cameras.
There is something wrong!
If I can't hand hold the camera or drag the shutter while the
camera is on a tripod I don't need it. See the two wedding photos
from this weekend.
Both of these were shot with camera on a tripod using a cable release.
My problem is there 90% of the time, manual or auto focus.
http://www.pbase.com/mbullman/fuji_focus_test
Looking forward to hearing from you.
Mike B
My problem comes and goes and does not appear to be affected byim getting some sharp pics so thats why i think me its a focus
prob, and when i use manual its more blurry than the af so
somethings wrong. maybe its the diaptor or something but the lenses
look fine from my f100 shots.
auto or manual focus.
Is anyone else working on this with Fuji? Where are you writing or
calling?
Thank you
Jim DeLuco
DeLuco Photography
Jim DeLuco
DeLuco Photography
Doug,Jim, David,
I had a look at your shots but the full size pbase ones are still
quite small reduced images. Images reduced by this much will
normally look quite soft without any sharpening applied. I almost
never use anything less than 12Mp for taking shots and get tack
sharp images from my Tamron 90 and Nikkor 50 and 35. I do try to
keep the shutter speed up though when hand held and no flash. Even
my Sigma 24-70 zoom gives great images from 5.6 up. Good enough to
print at 20x30 inches with great clarity anyway - the problem is
you can see the pores in the skin of a head shot that big![]()
Doug Jones
Canberra
http://www.panamagic.com.au
I still have more testing to do, but all the portrait images are taken with a tripod. The S1 candid was taken handheld (the last image). While the lighting on the last image is more diffused, I believe it is sharper than the others. Tell me what you think. It is true that when I shoot portraits, even outdoors I am often at 1/30th and sometimes slower, but always with a tripod. I've never had this problem with the S1, however.Jim,
I just took a look at your images and I'll agree that they are all
soft but I noticed that all shots were taken at 1/30th @f9.5, and
the first image was at 105mm. Were these taken hand held or on a
tripod? Do you have any samples taken at 125th?
Also, your shot taken with the S1 was at 1/45th of a second and if
all images were taken without a tripod, the shutter speed alone
could make a difference in image sharpness.
I looked at all 8 of your images and there really doesn't seem to
be a sharp area in any of them that would lead me to believe that
the S2 had focused somewhere other then on the subjects which
really makes me wonder if the problem is due to the 1/30th of a
second shutter speed.
I just looked at another gallery of yours (Schroter Portraits) and
I noticed that you use 1/15th of a second quite often and more then
a few of the images appear to be softer then I'd expect from the
S2. It would seem to me that since you're balancing your flash
with the available light that if your subjects moved at all you
would end up with a soft image.
What lens or lenses are you using? have you tried using a prime
lens to see if there is a difference?
Sorry for my ramblings.. just trying to help.
Tim
1600 for portraits does not work for me...unless you like the grain. Yes, it's cleaner than 1600 film, but it's still grainy. Also, you get a different look with flash and many times cannot get the skintones correct when mixing 1600 with flash.Unless you are specifically trying to get motion blur .. maybe its
better to up the ISO to 1600 from 400 and get two extra stops in
speed, which will make all the world of difference in sharpness due
to shake or motion blur.
ISO 1600 is really fairly clean, especially if exposed properly.
Its way better than ISO 800 film .. probably comparable to ISO 400
film quality.
My tests were done with two different lenses, but both zooms. 28-105 2.8 Tamron; 24-135 3.5-56 Tamron. I get similar results. I have to admit I have not done a controlled test and I really need to do this before I contact Fuji. I want to rule out user error.I did not read all theses posts here but I have the impression
that something is very wrong but not with the S2 in general.
I had/have focus issues with a 105Micro, wide open, middle distance
(30feet or so)... I was not sure if it was me, the lens, the camera
or what ... also it is hard to get a reference when you dont really
know what the camera can do under "normal" conditions and not
when everything is tweaked to perfection ...
My local shop gave me a D100 for comparison, a 60mm Micro, which
I wanted to test anyway and a 80-400VR which I knew was sharp,
cause I used it before and wanted to buy it.. (I ended up doing so)..
I have done an extensive test between the D100 and the S2 and also
used the S2 with the VR at Rally Australia and got dome stunning
pictures..
I have not yet solved my focus problem because it is identical
between the S2 and the D100 .. and only occurs with the 105 .. so
it might
be the lens .. I will test with another sample coming weekend...
As a side effect I ended up with a nice comparison of lenses and
cameras.
I have also compared the cams in the studio and done the same shots
under identical conditions for both cameras and all the lenses ...
I have tested:
28-70 AFS
50mm 1.4
60mm Micro
105mm Micro
80-200 2.8 ED
80-400 VR
I also do a colour study at the moment for 2 new catalogues coming up
and I use a dummy to do that .. so this is my model at the moment
until we have decided on the coloir schem and get the real ones in)
here some results:
taken with 50mm 1.4 at F8 1/125 Custom WB, ORG,ORG,STD,12MP
D100 versus S2 with 80-400mm @ 400mm F16 1/125 in the studio
and the crops
from S2
and the D100
crops without any processing no USM .. nothing ..
as a quick summary:
D100 is superior in functionality, display, speed but VERY bad with
AAs
S2 is superior in image quality by some margin ...
I have also done many outdoor shots where the differences are more
obvious...
The Lenses: at f8-f16 there is nothing between them ALL very sharp
I was very happy with the sample of the VR that I ended up buying it.
The D100 and the 60mm went back ...
Images I have seen in this thread earlier are just sub standard for
the
S2 and something basic is wrong here ... its not the camera in
general ... it may be an issue I still have with my 105...
With this lens I focus on a spefiic point and its not sharp .. only
30-40cm
behind .. but it only occurs wide open and its identical with the D100
so it could be a N80/F80 focus issue or simply a lens problem ...
I will find this out soon ...
Hope this helps ..
gmd
My tests were done with two different lenses, but both zooms.I did not read all theses posts here but I have the impression
pictures..
it might
cameras.
I have tested:
28-70 AFS
50mm 1.4
60mm Micro
105mm Micro
80-200 2.8 ED
80-400 VR
here some results:
and the crops
from S2
and the D100
as a quick summary:
AAs
obvious...
the
30-40cm
Hope this helps ..
gmd
One other factor that could be at work here is that we tended not
to look so closely at our film camera sharpnes. That is, we never
had the opportunity to review the image so closely cropped right in
camera and on a computer screen...so our personal tolerances may be
decreasing somewhat.
When shooting film, I rarely looked at a negative. I was looking at
4x5 proofs and could tell if they were critically sharp from those.
As soon as the lab changed paper on me I flipped out. My photo's
looked softer..but it was the new paper.
I wonder how our negatives would hold up under such close scrutiny.
Jim DeLuco
DeLuco Photography
Paul....there can be NO comparison whatsoever between the S2 and a
excellent medium format camera. I am using a Contax 645 with Zeiss
Planar lenses. You also have a MUCH GREATER dynamic range with
good professional film than you have with the S2. I must admit
that I was severely dissapointed initially with the results of the
S2, and now feel that most of the time, images are underexposed or
grossly overexposed, and images tend to be a great deal softer than
one would expect. The ONLY advantage to the S2 is that prints are
made instantly. Stuart.
I will do some additional testing, adjusting the shutter speed,
however with the Bar Mitzvah portraits, the ambient light was
probably at about 1/4 second at f9.5. I was shooting with flash
(main and fill) at 1/30th, f9.5 with tripod and there are no sharp
points on the images. Kind of scary.
I still think there's a processing problem but it could be the
placement of the ccd. Take a look at the Madar portraits on my
http://www.pbase.com/deluco/madar Those were also with the S2 and even
though these posted images are reduced I think you can see that
they are sharper than the ones taken two weeks later with the same
camera. I am afraid this is intermittent and is a processing
problem...I hope it is not.
Jim DeLuco
DeLuco Photography
