But I shoot Z6III, Z8 and Z9 and never have issues that you’re describing in the scenarios your images shared here show. You’re not shooting wildlife. Forget what those guys like Steve Perry or any “top wildlife shooter” say for your situation. You shouldn’t be doing handoffs - it’s absolutely unnecessary for static, single subject type portraits. These are photos where the mental energy required and active intervention into the AF should approach zero.
To be clear: I’m not suggesting 3D tracking
with subject detect active. I’m saying you use the two separately as complimentary AF modes. Subject detect for scenarios where the face is unobstructed and fairly obvious - you should be able to kick back, relax and let the camera take over. 3D tracking for scenarios where the face either isn’t providing the camera with something easy to grab (so you grab a piece of wardrobe or the body near the same plane as the eye); or you use 3D in a scenario where you
intentionally want to grab focus on a part of the body other than the face - or for example, if a player holds a ball toward the camera and you want to jump from their face to the ball for a shot. The fact that you describe these scenarios as equally problematic for the AF runs 100% opposite to my experiences. 3D tracking is an absolute champ for me, and frankly I’d never use subject detect at all it’s so good, except I periodically like being a laughably lazy b*stard with these new cameras and still nailing the shot.
I can imagine a scenario - “a couple years back” - where you were in a low lit environment and tighter aperture, the camera struggled. But that’s a thing of the past. Current Z8 firmware with the Lv open aperture focusing option mostly eliminates that as a source of problems. If you throw a cheap, lower powered LED into your workflow for AF assist, I promise you between that and the current firmware -
assuming good & consistent technique - you’re going to get near zero missed focus shots. And I’m only suggesting the AF assist for poorly lit, low contrast, tighter aperture scenarios (like in a gym) - the Z8 will benefit from it, and perhaps for the Z9 there’s situations where it’s absolutely necessary (IIRC the Z9 hasn’t gotten an Lv shooting update?).
If you’re missing focus semi regularly, especially some number of shots approaching/surpassing 5%, it’s absolutely user error.
TBH across a lot of use between the Z8 and Z6III I’ve seen my camera struggle to stay on a 3D tracked target once or twice, but these are fast moving, erratic situations with several high contrast/similar saturation objects competing for the camera’s attention. And this is exactly where you’d use Wide Area C1 with a smaller box to corral the camera into a narrower FOV for the AF, using Subject detect. And none of your photos resemble that situation remotely.
It’s so strange to read your accounts of Nikon’s top two cameras as struggling with these absolutely basic situations and know that my experience with the same cameras is miles apart from that. If you’re describing your Z9 - and especially your Z8 if you’re on current firmware - as struggling, or the 3D tracking or subject detect as interchangeably erratic and ineffective, I just… can’t relate at all. You’re doing something to sabotage what is an otherwise very easy, consistent and predictable AF scenario.
I’m wondering if you have somehow set up a workflow that interrupts or drops tracking altogether, somehow has it decoupled from taking the photo… especially with all of these examples you’re sharing where the camera acquires the eye, but then mysteriously loses it, or acquires focus elsewhere when the photo is taken. I can’t engineer a scenario with my cameras where that happens, and it points to a workflow that renders 3D or Subject tracking irrelevant at the time the shutter fires. AF-S and “focus and recompose” presents some possibilities where you’re disrupting what the camera would otherwise nail.
The fact that it only happens erratically, and only with a new lens - and only paired with strobe - I can’t really explain, certainly this thread hasn’t gotten me closer. It’s “a lens issue” but your approach to nailing down the problem is so fluid it’s impossible (for me) to diagnose remotely. I just know I shoot similar subjects, the same cameras, and almost exactly the same strobes (the earlier AD600Pros) and never have this experience.
Anyway, I’m tapped out. Best of luck going forward. Get an AF assist light - a cheap and compact 60w LED works. Update all the firmwares. Factory reset your cameras after that and start over. Meet up with a Nikon pro in your area, or travel to a nearby city for a weekend workshop and get some in-person coaching. Your AHA moment is out there.
http://jimlafferty.com
Evocative beats academic.
