The question is what characterizes the situations where the difference is visible and what characterizes the situations where there is no visible difference?
Why would that matter when there
are case after case where the differences ARE visible and easily obtainable?
Because some people like to tailor their workflow to the task at hand.
So you're suggesting some people, other than yourself, would rather get inferior data and use the products incorrectly, to achieve inferior, not recommended exposure?
An excellent use of a biased emotional plea. Have you considered writing advertising copy or working in politics?
The word "inferior" implies that the data is not good enough for the task at hand.
We could have just as easily phrased the question as "why would anyone, other than yourself, go to extra effort to get additional data that won't make a visible difference in the final print?"
However, both of these questions are off topic. The question that you have been unable to answer is what characterizes the situations where ETTR makes a visible difference in the final print?
For example, if I am shooting products in a studio, under controlled lighting conditions, there may not be a lot of dynamic range in the images. If my camera is at ISO 100, will people be able to see a difference in the final images whether I exposed the raw file for JPEG or used ETTR?
Note, this is not a question of which is "better", nor is it a question of which is "optimal". it is a question of how large a difference ETTR makes in this situation.
Exposing the raw for JPEG does have some workflow benefits.
Nope. Suboptimal exposure for raw. Just shoot JPEG.
What was said, what you'd see, what your homework is to produce is a raw + JPEG bracket to see how they all sync up (or as you'll see, don't).
You should be done with this homework by now Michael! It isn't hard.
If you're going to talk about homework, you should set a good example. perhaps you could provide proof that the difference between ETTR and exposing the raw for JPEG will
always make a
noticeable and visible difference in the final image.
You've made it clear that these are not benefits that interest you, however some people may be interested.
Well I'm certainly not trying to convince you! You have to do the due diligence and run some tests if you have a DSLR, maybe a printer and the right software.
Again, perhaps you should lead by example.
Set your camera to ISO 100 and setup a low dynamic range studio scene.
Shoot a raw file with ETTR, and shoot a second raw file exposed for JPEG.
Post process the images such that they look as close to each other as possible.
Make prints and run tests to see if typical viewers can see a difference between the two.
If the difference in quality is small, than some may choose to expose for JPEG.
Some? Speak for yourself. Better after you actually test this!
You're asking for proof that some people choose to shoot JPEG rather than raw?
Just read some of these forums. Lots of people choose to shoot JPEG.
Even if the only difference is an easier to see JPEG on the back of the camera, there are situations where that can be very helpful.
You'll find out once you get up from the computer and blow the dust off the camera
Sorry, I though we were talking about the merits of various workflows. I didn't realize you wanted to devolve to personal attacks in an effort to get yet another thread locked.
