I am interested in getting a new computer desktop since I only have
a laptop right now. I currently have a Dell Inspiron 8000 laptop.
I like the features and price point of the new Gateways. Since we
all do the same thing, I was wondering what most people are using?
Dell? Gateway? or Mac? and maybe some info on why you chose that
system. I hope you find this question interesting as I do.
Thanks,
Jamil
You basically have three alternatives:
1- Buy a name brand PC
2- Build your own PC from parts
3- Buy a Mac
1) advantages: you don't have to worry about integration and conflicts between peripherals, as the vendor has done the testing for you. Can be cheaper than building your own because the big vendors have purchasing economies of scale and with the cut-throat competition they are not overcharging as much as they used to for the privilege.
2) advantages: you can select best of breed components for everything. Used to be cheaper but is not always the case.
3) advantages: completely integrated solution, the new iMac is a very good computer (I have the superdrive version), unfortunately the affordable version is going to take a few more months before it is shipping in quantity
disadvantages: less software choices, although I've found this isn't really an issue for most people who don't use highly specific apps like Visio or Microsoft Project 2000.
What I did for my latest PC is to buy a barebones Athlon XP+ 1800 from AccessMicro and swap with the higher-spec memory, power-supply and case from my previous dual-PIII 800, and add a good video card, hard drive, NIC and sound card.
I would not recommend getting a dual-CPU, as many peripheral hardware vendors do not have multi-threaded drivers and stability becomes an issue. For instance, my dual-PIII workstation with a Matrox G400 video card had constant freezing problems in Windows 2000, while it works flawlessly in Solaris/x86.
If you like tinkering with computers, option 2 has great price/performance and can be a lot of fun, albeit time-consuming. If you just want the darn thing to work, the Mac will give you the best user experience. If you use OS X, shooting in RAW mode will be problematic until Canon releases OS X drivers, however.
If you choose a Windows PC, one key to stability is rigorous configuration management: always be careful about what software you install, partition your disk into a system+apps partition and a data partition, and make images of your system partition with Norton Ghost regularly so you have known good configurations to fall back to.
