Jerry, The results you got with the 40D are what you should be getting with the 5DII. This is all pointing to your camera having poor AI servo performance, most likely a tiny alignment error. As another poster pointed out, I normally use 1 series cameras with more sophisticated AF, but I have recently acquired a 5DmkII to replace my 1DsII. I have just gone and tested my 5DII plus 100mm macro and the results are indistinguishable in one shot or AI servo when viewed at 100% on the computer screen.
That is really helpful to know!
Three more questions: Was AF point area expansion enabled in your 5D2,
Did you test with an f/2.8 or faster lens, and did you use the center point?
I ask because
I found a solution to my problem and it involves AF-point area expansion (CF III, 7).
By turning AF-point expansion off, my AI-S misfocus problem totally went away. I'm guessing that is because one of the invisible auxiliary focus-points is prevailing, shifting the focus slightly. The camera was angled downward when I took the pictures, so I am seeing what appears to be front-focusing on a line of text below the main center focus point.
I am still concerned why another point prevailed when the main point had a high contrast subject to focus on. Your answers to my three questions may help.
Thanks so much, Ophrys.
Beautiful photos, btw!
JerryG
My galleries at:
JerryG
My galleries at:
http://www.pbase.com/jerryg1
