I want to remove the IR blocking filter and the mirror for deep sky objects
I have an old Nikon D90 with a busted shutter motor that I want to use for astrophotography.
I know what needs to be done, basically remove the mirror (Not necessary but gives better results than locking the mirror), secondly I need to remove the IR blocking filter.
Naturally, I will lose the autofocus, and I will have to use live view which is acceptable.
My question
do I need to add a clear glass in the place of the IR blocking filter on the sensor?
If the only reason to adding a clear glass piece is to allow autofocus, then I will not be needing that because I am also removing the mirror. So I will be doing manual focus using live view.
Or do you have another advice for me like buying a pre modified camera?
For landscape astrophotography , I have been using my Z9 but I also have a question there
Do the landscape astrophotography also require the camera IR blocking filter removed as in deep sky celestial objects?
The green comet taken with Z9
My question
