T-Rex Mark
- Messages
- 1,135
- Reaction score
- 1,067
SC, that’s fantastic, thanks again for sharing. I think the 14 model does have a higher clearance. I’ll look at both later however based on the reports, including your idle temps, and the 1-3C change Noctua is promising from a second fan I think I am getting a single fan model which has a great RAM clearing and I don’t even think it overhangs the RAM on this MB but will look again at the dimensions. The way you describe Noctua it sounds like a very well thought through / engineered device which I highly appreciate. I am also thinking to shift to the FD Torrent that apparently has better flow and will likely buy back my 3C with that
btw, what is your case?
No braces needed. My Noctua fan and heatsink has 44mm clearance between the botttom of the fan and motherboard which is ample to clear the Kingston Fury Beast RAM (see diagram). Note from a following comment I did not raise the front fan. It's in the standard position providing full air flow to the radiator. You can mount the front fan higher using the wire clips if you have tall RAM. The fan does cover the RAM but the front fan is easily unclipped if you need to change the RAM. I'm pleased I returned the ROG Strix board I originally ordered since I would have need to rotate the fan 90 degrees which is not optimum.SC, congrats on the build!! This looks great! So you used 120mm second fan on Noctua with Kingston Fury underneath, did you need to get any custom braces or all from the Noctua case?
I May end up with a very similar setup!!!
Thank you!!
Mark
Image not available. Click here to go to its original location (external website).
