Monitor Colour
I still have not calibrated my monitor (LCD) with a 'proper'
hardware system, but am curious to know in general do they usually
look 'warmer' or 'cooler' than the factory-default after
calibration.
Properly calibrated LCD will not look either warmer or cooler. In fact it will look exactly the same. Native white point and Native gamma mean that all the calibration does is measure the factory default output and record it in the profile.
Obviously you can choose a target that is either warmer or cooler than your Native white point. There are several reasons you may want to do it and there are several issues you need to be aware of if you do so.
Klinikl, Everthing you say makes perfect sense. Anyway I haven't had time to see the video that Bob spoke of, and the Eye One has just arrived on my door, so congratulations has to go to Colour Confidence in UK for a fast & efficient service! Work is going to hold me back now so it will be another 12-14 hours till I get into it.
Chris
I don't believe it! I Have calibrated my display after getting all the facts correct, and now I'm seeing all my 'colour managed' programs -RSE, Photoshop, Qimage, showing a yellowy-warm looking file that when viewed in Windows Raw Viewer looked correct and when printed from Qimage the resulting print looks like the Windows Raw Viewer view!
Helllllp!
Chris
Viewer view!
Helllllp!
Chris
I should add, the file (an adobe rgb photo with a lot of dark green (Scots Pine) foliage taken in fairly dull daylight) had only some minor contrast adjustments in RSE and some cloning of sensor specs in Photoshop before sharpening and printing.
Chris
"Obviously a major malfunction"...
Since it looks like you are using Windows XP first thing to ask is have you removed Adobe Gamma loader from your startup folder?
Second - what targets have you set in your Match 3 software?
And third - have you considered using Microsoft color control panel applet and it's LUT loader?
What is this Microsoft color control applet and its Lut Loader? I have heard it mentioned before but never really inquired about it till now. What is its main function. how does it work and where does a person find it? Thank You in advance.
Eugene
Yes!
Yes -just found this article which set me right ( Adobe Gamma Loader was not present in the 'Startup' folder anyway.)
http://www.adobe.com/support/techdocs/321608.html
'Native Whitepoint' -(says actual is 6100), and recently 'Native Gamma'-(says nothing for the actual figure here just has a dash).
Will have to look into that one!
Chris
Eugene
Good question Eugene, I think we should merge our threads!
Cheers
Chris
In the 'Match 3.6' software, when I toggle between Gamma Settings of 'Native Gamma' and '2.2 (actual results in 2.3 but that's another matter!)- I see an instant change of my Desktop from Blue-'Native Gamma', to Grey-'2.2 Recommended'.
If I stick with the 2.2 Recommended setting everything is fine (infact very good).
Anyone got any theories?
Chris
The software updates the LUT but until you finish and build a display profile, THEN go and view an image in Photoshop (or an application that uses the profile), you can't evaluate the color. On a Windows machine, I'm pretty sure your desktop isn't color managed so don't be looking there....
(infact very good).
If it's good, that's all that counts. Ideally a native gamma and white point will produce the same color appearance minus some additional banding in an ICC aware application. The less adjustments made to the graphic card LUTs (which is the result of the native settings) the better in terms of smoothness. Outside ICC aware applications, all bets are off but you can't view color with any degree of accuracy that way anyway.
Andrew Rodney
Author of Color Management for Photographers
The Digital Dog
http://www.digitaldog.net
(infact very good).
Andrew Rodney
The Digital Dog
Thanks for that Andrew.
I wonder why my system is not playing the game with the 'Native Gamma 'setting. I imagined that Native Gamma was just like the system default or standard and was just another number like 2.2 or 2.0 for example. I didn't realize that it was derived in a different manner from if you selected one of the other choices. So from what you say, in theory 'Native' should give a result which is more optimal for the system.
Chris
I understand more now. I realize that 'Native' means it is just in it's natural place without any adjustment. So adjusting it means the LUT has to reconfigure it away from it's natural position and thus can cause some undesirable effects. So I will have to find out what my display's 'Native Gamma' really is, anyone know how I do that?
Chris
Last fall Microsoft has released a Powertoy that helps XP-based artists with their colormanagement. It's usually not a requirment to install it but it makes your colormanagement easier to approach and understand.
It's LUT loader is one of it's optional features and it's only required when other LUT loaders ("Logo Calibration Loader" in GM case) in the startup folder don't work for your configuration for some reason. LUT loader is what causes colors to change on startup to match calibration results.
http://www.microsoft.com/downloads/details.aspx?FamilyID=1e33dca0-7721-43ca-9174-7f8d429fbb9e&DisplayLang=en
Or to download without validation:
http://www.softpedia.com/get/System/OS-Enhancements/Microsoft-Color-Control-Panel-Applet-for-Windows-XP.shtml
Since I don't have an EyeOne I can't tell how to measure Native Gamma. You said there was a dash in the "actual" gamma spot - that's where the measured Gamma is supposed to be. Does the software let you run some kind of validation or measurement after you completed the profiling process to just get the readings and compare to your targets? It's supposed to be able to do something like that.
and understand.
klnikl, At startup I do see the colour changes before it lands on the correct profile, and the Gretag loader is present in the Startup folder so assume that this side of things is working as it should.
Thanks again
Chris
that?
With an instrument (a colorimeter).
Andrew,
The colorimeter software is not giving me a figure for what the actual 'Native Gamma' is though. The software does let you preview how the different settings will look(providing you've previously calibrated with Eye One Match) and I just tried every Gamma point between 1.0 and 3.0 and you can clearly see the subtle changes in pixel brightness levels. But when I choose Native Gamma the appearance looks vastly different from any of the other gamma points ... looks almost as if its also whacked up the White Point to somwhere around 9300!
Chris
like that.
klinikl, The only validation is where that dash (actually looks like three very-close-together short dashes) is. You can compare how things look between the previous profile and the new one but that's about all.
Please see my response above to Andrew (digidog).
Cheers
Chris
That be nice but it's not necessary. First, its probably somewhere around 2.0-2.2. But the point is, the instrument and software are measuring this native gamma (if the software has the option) and leaving the gamma alone (no gamma correction on the LUT) and defining this in the ICC profile. That's the important point.
Andrew Rodney
The Digital Dog
