From posts on this topic I understand I need the Nikon SC-EW3 cable for the camera (CP-5000) end.
I have not been able to locate a Visor to Serial modem cable but I do have a mobile usb hot sync cable. Can I replace the USB connector end with an appropriate gender db-9 serial connector to make this work? (Did find a serial cable online for $40 but the usb cable was only $7 so I am hoping it can be modified).
Using a continuity tester it appears there are only 3 connections between the Visor and the USB connector (though the USB has 4 connectors plus ground). Can anyone tell me the pinouts from the Visor to the serial connector?
If the USB hotsync cable cannot be modified then I would modify a serail hot sync cradel by replacing the serial connector with the right gender and rewiring new connector appropriately. Can someone tell me the pinouts for such modification?
Does anyone have a source for a Visor to serial modem cable for less than $25?
Thanks!
Thanks!
