Report from a collegue in Barcelona, Spain
The Mark II has not been received very well in the world of Formula
One at this weekend's Spanish Grand Prix.
It's especially the colours that have caused a lot of uproar,
eventhough the sharpness is also a problem for most (being used to
the sharpness of the 1D). The camera is hardly able to capture the
red of the Ferrari's and also the yellow's of Jordan and Renault
looks very dull. I can only second that after shooting with it for
the first time last weekend, although the reds look better on my
CRT than on a LCD screen.
There was so much dissatisfaction, that Canon decided to flew in
somebody from Canon Europe. Yesterday, he collected a lot of RAW
files from many photographers which will all be send to Canon Japan
for analysis. Canon has a huge market share in F1 (around 80% I
think) and motorsport in general so they are determined to make
everybody happy again.
It seems that Canon has been very reserved in processing
out-of-the-camera JPEG's. The best settings found so far are to
setup a custom Color Matrix and custom parameters. Here's how to
set them.
The parameters and color matrix settigs are both under the first
menu. Select Set 1, 2 or 3 for parameters and choose Set Up to
change the parameters. Choose the set you selected and set the Tone
Curve to Standard, Sharpness to 2 or 3 (to your liking) and
Contrast to +1.
Go back to the first menu and choose Color Matrix. Select 6CM set1
or 7CM set2 and choose Set Up to change the settings of that Color
Matrix. Set it to color space sRGB or AdobeRGB (to your liking),
Saturation to Mid. High and Color tone to 0. You might want to
experiment with the Color tone to your liking. Some report that
setting it to 1 is better.
This is so far the setting which is though to give the best
results. For sure Canon will come up with a good solution, probably
in the form a firmware update which should at least fix the red's
and yellow's.
Grtz,
Marco
