David A Bigwood
Well-known member
ditto
Report from a collegue in Barcelona, Spain
The Mark II has not been received very well in the world of Formula
One at this weekend's Spanish Grand Prix.
It's especially the colours that have caused a lot of uproar,
eventhough the sharpness is also a problem for most (being used to
the sharpness of the 1D). The camera is hardly able to capture the
red of the Ferrari's and also the yellow's of Jordan and Renault
looks very dull. I can only second that after shooting with it for
the first time last weekend, although the reds look better on my
CRT than on a LCD screen.
There was so much dissatisfaction, that Canon decided to flew in
somebody from Canon Europe. Yesterday, he collected a lot of RAW
files from many photographers which will all be send to Canon Japan
for analysis. Canon has a huge market share in F1 (around 80% I
think) and motorsport in general so they are determined to make
everybody happy again.
It seems that Canon has been very reserved in processing
out-of-the-camera JPEG's. The best settings found so far are to
setup a custom Color Matrix and custom parameters. Here's how to
set them.
The parameters and color matrix settigs are both under the first
menu. Select Set 1, 2 or 3 for parameters and choose Set Up to
change the parameters. Choose the set you selected and set the Tone
Curve to Standard, Sharpness to 2 or 3 (to your liking) and
Contrast to +1.
Go back to the first menu and choose Color Matrix. Select 6CM set1
or 7CM set2 and choose Set Up to change the settings of that Color
Matrix. Set it to color space sRGB or AdobeRGB (to your liking),
Saturation to Mid. High and Color tone to 0. You might want to
experiment with the Color tone to your liking. Some report that
setting it to 1 is better.
This is so far the setting which is though to give the best
results. For sure Canon will come up with a good solution, probably
in the form a firmware update which should at least fix the red's
and yellow's.
Grtz,
Marco
Here is some stuff from the Monaco Grand Prix Historique last
weekend. Included are some shots of the Ferraris from a couple of
years ago. The pictures were taken in RAW+samll jpeg using the
settings recommended here.
http://www.kyleburtphoto.com/Events/MonacoGPH04/
--http://www.kyleburtphoto.com/Events/MonacoGPH04/
set them.
Contrast to +1.
and yellow's.
Grtz,
Marco
How did you create that effect? Is it simply a VERY slow
shutter-speed pan? If so, what speed? Or is it a combination of a
slow shutter speed and fill flash? Paul-Henri Cahier and Rainer
Schlegelmilch do a lot of this sort of shooting and I've always
wondered what technique they use to create that effect, where there
is a lot of overall blur combined with a focal point of clarity
(usually the driver's head and surrounding area).
Thanks in advance.
VBob
That was a very slow shutter speed1/20th f/16 17mm on my 17-40f/4L.
I did use flash to brighten things up as it was raining, but It
didn't add to the effect much (I've done many similar shots without
flash). I know Schleg does a lot of zoom pans (he was shooting next
to me the very next session from that same location), but I didn't
with this one. The slow shutter speed combined with the wide angle
lens and close distance did the work for me.
Hope this helps,
Kyle
When you use the flash, do you use it without a diffuser and
straight at the car? I worry about disturbing the drivers in that
scenario, but apparently it doesn't. Also, from the blur at the
front of the car, it looks like 1st curtain shutter sync; is it?
I'm sorry to sound like I'm trying to pick your brain, but actually
I am. To the extent that you guys who are successful at achieving
that effect are willing to tell me about how you do it, I
appreciate it. It's a lot easier for me to learn to begin new
things by asking for pointers when they're available. Just making
me think in terms of wide angle is a giant leap forward in my
attempt to create this effect.
Were you shooting Monaco by chance for Randy at VM (I see that you
do shoot for him), or for some other publication?
Thanks again.
Bob
Hope this helps,
Kyle
Bob,
This was actually my first time using flash out on cousre so it was
a new experience for me - I just wanted to brighten things a bit so
I dialed in -1 stop flash exposure. I didn't use a diffuser, but I
am bothered about affecting the driver so I tried not to get them
ead on - also it was the second slowest coner - Rascasse - I do
wish I had tried the difussing panel on my 550 - maybee next time..
I did notice a few things - the flash illuminated the rain on some
of the shots, which could spoil the effect fortunalteluy it wasn't
raining that hard so It was only a minor item. Theere was a high
reflectance sign in the background which sort of stands out on a
few shots because that item looks frozen where everything else got
the pan blur. Yes it was 1st curtain sync - well spotted. I nver
thought it would make a difference on a pan shot because the car
should be relatively the same position in the frame at the begiing
to end of the exposure, execpt here the positions aren't stationary
due to the wide angle and long exposure - so I learned something
today. Yes, I was shooting for VM - the article will be in the next
issue which is due out in early July so keep an eye out for it.
Kyle
Did you use the settings I suggested in this thread?The reds from this camera are terrible. They are so over saturated
its not funny. I shot a race this weekend and the Hondas were all
weird looking. I hope this gets fixed soon.
