It seems to me that without flash if the view is too dark it means the image will also be too dark? In other words on my a6000 I see what I get when live view is set to on.With the flash light flip up (enabled), I am still able to see my subject clearly n do my MF with peaking when using a manual macro len with aperture closed (~f11-f13) . Without the flash my liveview is showing darkness at the same aperture.
with this I can consider getting a purely manual lens.
I think that should work.I have a flashlight installed on my len as focusing light to aid in night macro.
Now im considering getting a viltrox jy610ii (small flash which is sufficient enough for my macro.. And use my hvl-20s to wirelessly trigger it ?
I was able to get 1/250 with the Sunpak (could be a limitation of the Sony flash)Only problem is is still the 1/160 flash sync speed. Not able to help me freeze the image also manual lens don't have OSS. Furthermore I ain't using tripod when shooting.
Dawson
but posters above where using low power settings (faster flash speed) and not fast shutter speed to freeze action. (but this may require a more powerful flash) --otherwise it will require a flash capable of HSS
