Lightroom 4 corrupting RAW files / 'Unexpected end-of-file' error'
Your description told me that you have hardware problem. You Definitely Need to Replace your Hard Drive. Suggestion to do it now before it damages all the contents.
I am sure your advice will be very useful, to the year 2012.
still: thx for taking the time to reply.
for sure I also considered a hardware failure very early in the process ... but: problems *only* occured with NEFs, not with other file-formats ... therefore a HDD/SDD failure seems unlikely to me.
interestingly enough: the problem might have also been on Apple's side. At a certain moment (OS update?) problems ceased to exist. And I 'heard' some 'rumors' that Apple had some issues in the meantime which were 'silently fixed' ... :-/
FYI: MacBook (late2008 unibody) got replaced by a 2012er MacBookPro-Retina ...
SpaceDoc
LoL
Was there ever a solution to your file corruption? I am having the same problem and have seen other threads of people having the same issue. I believe it's a LR issue as the file is fine on her parts of my Mac.
Doubt it, as ACR and LR are read only products in terms of handling of raw data. That's why they write sidecar files.
Might try converting the proprietary raws to DNG and see how that goes.
Well: files were corrupted on my machine at the time ... so more than 'read only'.
Why should a conversion of an already corrupted file result in a non-corrupted file?
SpaceDoc
Sorry, you're logic of blaming the software doesn't wash. There are all kinds of reasons files can be corrupted. Like the drive, OS, etc.
SpaceDoc
You can't convert or do anything with a corrupted file! You could convert good files to DNG and see if they get corrupted as LR/ACR do write to the files (not read only, no need for sidecar files). Now if, as I suspect, you've got some hardware issue, the DNG's too could become corrupted. But again, proprietary raws are read only so the possibility that the software reading them is corrupting them doesn't sound kosher. At least no one here has provided proof that this is the case?
