Is extended iso range the only camera spec more useless than native iso range? I doubt any photographer is going to think an iso of 100k on aps sensor has an acceptable amount of noise.
Depends on the camera, subject, photographer just like anything else.
There ARE cameras with even smaller sensors designed for ultra high ISOs (Canon made/make a few mainly video cameras both FF and smaller sensor that go to ISOs in the millions).
I am more worried about DR at higher ISOs than noise and some cameras are better at higher ISO than others and the other way around also applies.
Native ISO range is very useful for me a lot of the time.
I had thought "native" iso was the iso of the sensor to which no gain was applied. So it was a single number and not a "range".
This is a commonly put about idea, but is essentially wrong-headed.
ISO is not 'gain'
Correct. It is the effective sensitivity of the camera and should be referred to as the ISO sensitivity setting.
ISO says it is an 'exposure index'. The latest version defines 'photographic sensitivity' which is 'general term for numerical values based on the exposure at the focal plane of a DSC which produces a specified DSC image signal level, such as the standard output sensitivity or recommended exposure index'.
In other words the effective sensitivity of the camera (DSC).
That depends entirely on what you mean by 'effective sensitivity'. It requires an unusual interpretation of the word 'sensitivity' to make it mean the same as ISO's own word salad. Even more so when you actually read the standard. For instance the 'specified DSC signal level' under the recommended exposure index is 'the arithmetic mean focal plane exposure, expressed in lux-seconds, recommended by the DSC provider'. That is, the 'specified signal level' is whatever the camera manufacturer chooses to recommend.
I think you'll have a hard time finding any other 'sensitivity' defined as 'whatever the manufacturer recommends'. The 'standard output sensitivity' is little better. That says that the specified signal level is 'equal to 461/1000 x Omax, where Omax is the maximum output value of the digital system'. So, even if one thinks that 'sensitivity' is synonymous with 'responsivity', this is a standard where the 'effective sensitivity' might be changed simply by changing the value of a number (Omax) in software.
Simply, this definition of 'sensitivity' aligns with no other usage of the word in a technical domain.
The standard says exactly this about terminology:
'Note 1 to entry: In practise, the photographic sensitivity is often called the "sensitivity" or the "camera sensitivity". It is sometimes called the "ISO sensitivity", for historical reasons that date from ISO standards for photographic film cameras.
So the photographic sensitivity [of the camera] is often referred to as simply sensitivity or camera sensitivity for historical reasons. That makes sense when one is dealing with photographic standards created over a long period. Consistency is the whole point of standards.
It also makes sense if you're looking for agreement on a committee of diverse interests and views.
So, they don't say that it 'should' be referred to as the ISO sensitivity, they say that it is sometimes called that.
Or camera sensitivity or simply sensitivity. All as defined by the ISO standard. Thus ISO sensitivity.
They say precisely what they say, that it is sometimes called sensitivity, not that it
should be called sensitivity.
All the rest of your post is an elaborate fantasy created by you to justify calling the ISO sensitivity setting anything other than what it is.
If there had been a technical reason for calling it 'ISO sensitivity' they would have given it, in fine detail and with formulae that explained it. The very fact that they say that it is for historical reasons means that there is no technical reason, but a historical one.
