Neither do I. Pictures lack consistency.
That's because you aren't using it properly. If you have a method of exposure setting with manual ISO, then there is an analogue for auto ISO that will achieve exactly the same results, but you need to think it through. In general though, it pairs most easily with a raw workflow.
I think I'll stay where I am. And I do RAW only.
Well, of course it's your affair how you work, but it would be interesting to discuss the reasoning behind it.
I think you overestimate me. I use simple processes, some of them are simply force of habit. For example, I always shoot RAW, I never use Auto ISO, I never use Spot Metering, 99% of time it is Aperture priority, simple things like that. I would not even attempt discussing them, that's the way I like them. You may call me limited, I am perfectly fine with it.
I haven't called you limited, but if it's just 'that's my preference because it suits me' there's not much anyone else can take from that. Their preferences could be different and their's no reason to think that they might be better or worse. So coming back to the thing being discussed here, whether or not auto ISO is a good idea, there's no reason to think that what you choose illuminates the discussion.
Pictures taken at different ISOs are not the same, if there were, there would be no upper limit to ISO.
Maybe we could discuss the ways that you think pictures taken at different ISOs are not the same.
Not sure what there is to discuss. That they are not different? Or, why are they different?
I was thinking about how they are different, which might lead to understanding whether they are significantly different.
I think you may need a better partner for your discussion. I am satisfied with simple: They are different.
The real point I think is that for you 'it's my personal preference' is a satisfactory reason for doing things, but as above it's not something anyone else would be interested in.
It's true that higher ISO settings tend to produce less noise,
Actually, the reverse is true.
Nope. Higher ISO settings in general produce less noise. That's a demonstrable fact. It's why cameras are engineered as they are.
