it's not hard to learn this at all but even if you don't want to, there are tons of custom pc build it for you companies out there. so unless you think using a drop down menu is too hard, idk what to tell you. it's the same when buying a mac lolYou still need to know what components you need to get what you want out of it. Putting it together isn't the hard part. Knowing what you want to put together is.as if you can't just buy pre-built pcs or use a company that assembles it for you then ships it.For me, at the end of the day you have two options.
1) get the mac and be done with it.
2) learn what parts you need, what works together, what the differences are between a long list of components, what workflows work and the problems you may have (converting to other formats takes time and space).
The idea of upgrading a PC is great. But the reality is that quite often you'll want a new processor, a new motherboard, new memory, larger disk, and a graphics card. The only thing you're not upgrading is the power supply and the box.
It's not totally pointless, but you'll have to enjoy that process as well.
Let's go for the basics.
Should I go for a AMD or a Nvidia card?
That alone gives me over 20 options on series... That's not even specific cards, but just the series... Do all work? Do I want one brand over the other? Do I want one specific series? Do I need the most expensive one for video?
Using a drop down menu is easy, but knowing what to select isn't that simple.
