I never had one to use, but for those who did:
was the depth of field scale on the LCD on particular Minoltas as useful as I think it should have been?
cheers
Flakey
flakey
I think you are talking about the Minolta Maxxum/Dynax/Alpha 7 film camera, which was the only camera to have this feature. Some of their earlier cameras had scales that only showed relative DOF without any actual measurements provided.
I find the 7's DOF scale useful in some situations. However, there are some limitations:
1. only works with "D" lenses (at the time these were limited)
2. Does not work with all third party "D" lenses -- some Sigmas gave strange results, such as the near end of the DOF being behind the camera, probably a function of arbitrarily selecting a lens ID or not passing all the info needed to the camera.
3. The DOF scale showed the front and back DOF from the focus point not from the camera. That was unusual for those used to using DOF scales on a manual focus camera.
4. There were no options that could be set by the user, such as desired max circle of confusion - for large enlargements, the user might want a smaller COC than for small enlargements. This was actually no different than the DOF scales on MF lenses, because you often didn't know what COF the lens manufacturer had used for their DOF scale.
It should be easy to include a DOF function on a DSLR, and I'm suprised that Sony hasn't done so. I would like one to have some options that would allow me to set the camera focus and aperture the way I would on a MF camera when I want to control DOF. One method would be to focus the lens on the near distance and have that value recorded, then the far distance and record it, then focus on the key subject that has tyo be sharp and have the camera recommend the aperture or show DOF for my selected aperture in relation to the desired near and far points. (Canon high level film cameras had a similar feature where once the points were focused on, the camera would set focus and aperture to keep them in the DOF, not sure if they continued it in the DSLRs). Also having hyperfocal distance displayed (in relation to a subject) as the aperture is adjusted. Also allow different CoC to be entered.
Those are some ideas, but I'd have to think them out a bit more to pick out what is most useful.
The problem today is that the Sony cameras (and other manufacturers) have removed all of the pre-shot methods for planning DOF. (No distance scales on many lenses, no DOF scales on zooms, short focusing arc on AF lenses, no DOF preview). I don't use DOF preview with most of my MF cameras, because use of the lens scales is accurate enough and the VFs are darker than my AF cameras when stopped down. Since a DSLR is a computer, they really should use its computing power to give the user useful information.
I don't like to chimp - Need reading glasses, miss the oportunity to get the one time shot, poor ability to evaluate the image on the LCD when shooting in sunlight. So I'd really like to plan my shots and bracket if necessary.
Tom
