NO AF SYSTEM IN THE WORLD is foolproof. There are "real world"
situations that are easy for AF systems, some that are pretty much
impossible, and everything in between. They are ALL "real world"
photo situations. If you want pro quality results, you have to get
beyond the point where you expect that the AF system will work in
every situation, reading your mind as to what you want it to focus
on. It can't.
The unfortunate part here is that you have chosen some of the more
difficult photo situations. I don't say that your first post was
that difficult, but you could have helped your system in that case
by focusing on the carving or the man and then recomposing.
Instead you chose a much smaller, lower contrast object to focus
on. You opened the door for error that you did not have to open.
I can't explain the rocks - I have no idea how close you were to
them.
The wire cage is a classic problem for auto focus (and cleary not
BACKFOCUSED), as is the squirrel through a whole passel of tree
branches. This would be one indication that your lens is not
backfocusing. The wire case shows nothing in the "back" as in
focus.
If you want a point and shoot camera you probably should not have
bought the 10D. That said, any point and shoot you buy will have
similar limitations with regards to autofocus. In fact they will
have more limitations. You might not notice them as much because
the P&S digitals have such a large DOF almost all the time.
Learn how to help your camera to find the right focus. The more
thinking you do behind the the camera, the better "thinking" your
camera can do for you.
Having said all of that, your camera may indeed have a focus
problem. Personally, however, I just couldn't be certain given the
shots you have posted so far. If it were my camera, I would want
to convince myself that the camera/lens is or is not at fault.
Yes, I would pick the easiest case for the camera so I could
determine that WITHOUT A DOUBT. If it's the camera or lens ,
return it or get it serviced and move on.
However, if the camera/lens combination work properly, then you
have to go back and examine problem photos and try to LEARN from
them what went wrong and why. Add that information to your
technique and use this approach to help make you a better technical
photographer. It will stand you in good stead with whatever
equipment you are using.
I'm sorry if I sound harsh. I certainly am not trying to do so. I
just can't be certain that you have an equipment problem given
these photos.
= Ed =
I'm shooting real world shots, just like most advocates of the
"there's no aF problem" crowd suggest, and apparently "THESE" real
world shots aren't what they want either.
Now, that aside, let me see if I understand what some folks are
saying.
I should shoot a picture of some object that will encompass the
entire AF sensor (although you really can't tell how big it is by
the reference in the viewfinder) in good light and if that doesn't
focus properly, then I have a problem?
But otherwise, if I EVER want to shoot a subject that may not be
covered by the entire sensor or that may not be in optimal lighting
circumstances, it's a cr*p shoot that the subject will be in focus.
Is autofocus that undependable? It didn't seem to be with my
28-135 IS.
VES
= Ed Rotberg =
'A waist is a terrible thing to mind'
http://www.edrotberg.org/gallery
