Rubio
Well-known member
No text
--Is it the same with different types of lenses?
When I see your example its shape makes me think "Lens Flare", but it
must be of an unusual kind (reflection of something in the camera
back onto the sensor) since it appears with lens cap on.
'He not busy being born, is busy dying' Bob Dylan
I'd say this is a houston we have a problem with the camera issue.From my experience, this would imply that the focus confirmation
light is coming on when it should never, ever, be on: during and
exposure, and when autofocus is off, AND ONLY at one lens setting on
one lens, and that this error were somehow happening in the exact
same fashion on two cameras designed years apart . . . I don't see
this as the likely culprit. I could always be wrong, but for my
money, this isn't the issue.
It doesn't close the shutter? Why not?I disagree. When it generates the dark frame all that happens is the
mirror flips back down. That doesnt impact light coming from the
viewfinder or other internal areas within the camera.
If it was the focus confirmation LED then you would still be able to see it through the viewfinder, even though the mirror was up. I don't think that's the problem.to be the focus confirmation LED?
After all that one is inside the body somewhere near the focusing
screen.
Forgive the bad manners of replying to my own post, but it seemed the most appropriate place to add this update.Interesting. I notice that the EXIF data on the OP's example imagean example with the 5D (original) with the 24-105 @ 24mm, 400 second
exposure at ISO 800. the red streak on the left side of the is
image, and is always in the same relative place with the 5D and 5D2
but ONLY when i use the 24-105L at 24mm.
was shot under similar conditions:
ISO800
24mm
f/4
902seconds.
Was the OP image shot with a 24-105L4 lens at 24mm?
Strange that this ghost red image should only appear at 24mm though -
does it appear constant at all apertures?
I just ran a series of exposures in a completely dark room with the
lens cap on, the viewfinder blocked out and the camera face down to
stop the 24-105L from shifting from the 24mm setting. So no chance
of any light getting onto the sensor that isn't generated by the
camera/lens itself.
Its RKM
camera/lens itself.
Its RKM
hmm.After reading your post again, it seems that the light is coming from
the lens, so perhaps the lens uses infrared proximity sensors to
provide position feedback for the IS servo loop.
--I am at first skeptical of a light leak there, since there were no
red lights around my camera (while there sometimes are red lights
around due to my red flashlights, I have yet to see any images
affected by this) . . . but more importantly: this flare shows up
identically placed, even when I have tested with strict control of
any lights . . . that is, I have tested my lens in an area where I
can guarantee no lights of any type and I still get the same flare.
