First time I saw “temperature limit reached” was 5 minutes after unboxing, updated firmware to latest 3x and it started to show up occasionally after 10-20 minutes of camera usage
Sometimes right after start in cold temperature (-10C) sometimes no error after 4-5k photos in preshot.
When error happens, camera reboots and then works normally for some time. Battery and card are cold, camera a little bit warm but far from being hot
Full Settings reset, working without card, disabling boost, raising Temperature limit to “high” in menu - no luck, once was able to replicate error even without lens
Tried last trick before return - placed camera and battery separately in the fridge (-24C) for two hours … and now it seems to work correctly - tried “burn-in” test - after 5 minutes in 6k prores422+proxy recording warning icon raised (never saw it before), after 10 minutes - “temperature limit reached”, camera warm, battery warm, card - hot. Rebooted, started h265ai recording - after 1 hour - no error, no icon, camera finally really hot
Not sure what exactly helped - fridge or leaving camera without battery, but what was that? I used t2, t3 and t30 in the deserts under direct sun at +45C without any errors and reboots. I understand h2s is “hotter” by design but that behavior with shutting down after several photos in cold weather was totally erratic.
Is that some kind of temporary software error (doubt, firmware update for sure rebooted camera) or calibration error (never saw self calibrating temperature sensors in such simple applications as measuring cpu temperature), or I should replace camera? Anyone had same issues?
