I noticed the GTX myself. The pictured GPU is not an RTX, either 2060 or 3090.
It's also an Asus card, not eVGA.
Sorry for the confusion. I removed the RTX 3090 card that was shutting down on me and installed my old GTX card. The GTX has been going for over an hour without shutting down, but it is crawling.
I wonder what card it is? It appears to
not be an RTX anything. Not a 2060.
A couple of things: the PCI-E slot nearest the CPU has its PCI-E lanes provided by the CPU. That's the preferred location for the GPU. (But it has mothing to do with your issues.) I suppose that you have reasons for not using it, but I'm curious as to what they are.
If you had the card in that slot, you might get better airflow. There's not a lot of space between the fans' intakes and the case bottom.
Did you have any bracketry to support the end of the 3090? (Towards the front of the case?) That's recommended for a heavy card like a 3090. I can't be sure, but it looks like the card in the picture is drooping. (Can crack the PC board of the card.)
