I am the happiest guy right now.
First, I moved the GPU to the PCIe slot near the CPU and used my tripod plate to support it and prevent it from dropping. Second, I installed MSI Afterburner and played with it. I didn't know what I was doing, so I can't say whether MSI Afterburner helped or not. I did tweak the GPU power a little. I'm not sure if I went up or down.
But I am almost positive that moving the GPU to the PCIe slot on the top slot did the trick. It gave the GPU breathing room to take in some air. It was very dumb of me not to have realized that. This thing ran so smoothly that I didn't even hear the GPU fan kick in. Usually, it kicks in after a few minutes of running with a loud whining noise.
I won't even bother building a new PC. You guys just saved me $5500, which I was planning on spending on it.
It's a good card, I wouldn't replace it.
When you have the time, you should double back and look at the Afterburner software and become acquainted with it, with that kind of card, at the least.
At the most? Many a bit-coin miner, swapped out the default thermal pads on the GDDR memory chips with GELID thermal pads, and replaced the GPU grease with better stuff. The GELID pads are key though, which if you note on your thermals? Your GPU is hot, but your GDDR's memory peak temps (100c), are hotter, that's typical in fact. You should be able to squeeze more performance out of it after, too, not just stabilize it by improving the cooling situation.
Again, I'd aim to "fix it" before optimizing it though, and not when you have a workload backlog to attend to as it may take some trial and error over a couple days, or a single day, if you're dedicated
This is par for the course...
https://chatgpt.com/share/64b27d75-3899-4800-880c-9219695ebb29
Now I wanted ChatGPT to search the web and give me a real thread, however, this is VERY typical, and comical. Worth sharing, heh.
BTW, Thermal Grizzly Kyronaut Paste, is the best for paste anyways. GELID pads, are the best, for pads. The GDDR is going to be your weakest link. Don't bother with Liquid Metal on a card like this unless you really know what you're doing, and even then? Still wouldn't.
