A digital camera, lens, sensor combination that is optimized by design has much more merit than a sensor size that is designed to maintain use of some old film photographers lens collection.
You would be the troll who is making an unwanted appearance on my thread. Guess I will give you a pass since you appear to be hyper excitable. Maybe a shot of scotch will help you. Its Friday, have one on me.
The reason that sensor size was chosen in the very first place was because it was an optical design optimum with practical advantages. Give or take a millimeter or two.
This is first-year engineering stuff. You should not be so self-certain.
You need to consider "Digital Revolution" again. If you don't think that the design equations have significantly changed, then I certainly can't help with that.
What does "digital revolution" mean to your argument? What do you think I should be considering. Tell me where the design equations have changed in this regard.
One more time. If you do not recognize significant change in design variables as one moves away from film based camera design, to digital camera design, then I can't help with that.
Let me try. Developer, Stopper, Water Bath, Dryer. Then we go to the enlarger. Can't wait to see the pictures!
So you list the obvious things we both know, none of which pertain to the question.
Is your claim that there is a new design optimum? Great. Just tell us what it is.
It is no longer "It". It is not "35mm film". Are you saying that Sony did not optimize its a77 design with its crop sensor? Are you saying that Canon did not optimize its FF 5dIII design around that gigantic sensor?
Why don't you try to tell me how an old film camera was optimized around storage media, power battery life, FPS, s/n ratio, max ISO, sensor size, buffer size, and processing speed.
You're asking the wrong questions, so as to presuppose an answer. Of course no old film camera was ever designed with a consideration of technology that didn't yet exist. However, many things are invariant in design considerations in both film and digital:
The 35mm form factor was designed around a near-optimum combination of (1) size for a receptor surface and ability to record sufficient photons with high fidelity, (2) optical design sweet spots, (3) ability to gather light sufficient for everyday situations at reasonable shutter speeds, (4) mechanical design, manufacturing, reliability, and usability considerations, (5) ability to produce very good enlargements for publication or presentation, and last but not least (6) human usability factors.
You began here by claiming that the full frame sensor had no noise advantages over crop cameras. Do you still believe that? If you still believe that, there's no point in reading the next paragraph until you get straightened out on the basic math.
My questions for you:
What sensor size do you believe to be the optimum for a digital camera?
What range of sensor sizes do you believe ought to be made?
