R
Ron Parr
Guest
You can construct pathological images like this, but these will not reflect actual performance on real images.If I have my theoritical "white" wall with "red" dots/squares. I
am only interested in how many "red" sensors there are.
Yes and no. You're sampling the luminance signal at a higher rate than the other channels with Bayer, but you're more sensitive to the luminance channel. Most of the time it will appear as good as if you sampled the luminance from every other pixel.True .. but the same is true if you interpolate a X3 file to aNow you have the problem of interpolation. Yes, interpolation is
guessing information and it's impossible to be right all of the
time. However, it's also impossible to be wrong all of the time.
The actual performance is somewhere in the middle.
higher density. The fact remains that there are only 1.5m "groups"
of pixels able to produce "white" dots in a conventional 6mps
sensor ... there are 3.54m of those same "groups" in X3.
THE ONLY DIFFERENCE IS THEY ARE STACKED INSTEAD OF SIDE-by-SIDE.
I'm not trying to argue against the X3 approach. It's just that you're oversimplifying things. The Bayer pattern was designed to do a good job of hiding the limitations of interpolation on the majority of images. There's no free lunch, but on many images it will do a better job of fooling you than the pixel count would suggest.
If you're expecting a 3X improvement with the Foveon chip, you'll be disappointed. I don't like the whole numbers game, but there's one thing I'm 100% confident of: a 3X improvement on typical images is too much to hope for.
Ron Parr
FAQ: http://www.cs.duke.edu/~parr/photography/faq.html
Gallery: http://www.pbase.com/parr/
